1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Prioritizing Channel Access per Record?
To: EPICS Techtalk <[email protected]>
Date: Tue, 18 Mar 2014 11:47:04 -0400
Is there any way to specify that CA delivery of updates from certain records should be prioritized over other records on the same ioc?
I've got an application where a bunch of ai's are processed at 10Hz and some relatively big (for us) waveforms are processed at about 0.3-0.5 Hz. The ioc is not heavily loaded and all record processing seems to happen in a timely way, but from the client end (EDM) the "fast" records all pause for ~0.5 sec whenever the waveforms push out their CA updates.
The ai's are already being processed at a higher priority, but this doesn't seem to help their updates get pushed out with higher priority.
Is there some tinkering I can do with the priorities of the CA threads to get what I want? How can I tell which thread will get which record updates? Is there something more obvious I'm missing?
--Brian
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
     "The urge to save humanity is almost always only a false-face
      for the urge to rule it."
                                     -- H. L. Mencken
Re: Prioritizing Channel Access per Record? Ralph Lange
RE: Prioritizing Channel Access per Record? Mark Rivers
Prev: Re: Installing EPICS on the Raspberry Pi Pete Jemian
Next: Re: Prioritizing Channel Access per Record? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Recommended practice for cvtRecord chain initialization Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
