1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Prioritizing Channel Access per Record?
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 18 Mar 2014 17:03:20 +0100
On 18.03.2014 16:47, Brian Bevins wrote:
Is there any way to specify that CA delivery of updates from certain records should be prioritized over other records on the same ioc?
I've got an application where a bunch of ai's are processed at 10Hz and some relatively big (for us) waveforms are processed at about 0.3-0.5 Hz. The ioc is not heavily loaded and all record processing seems to happen in a timely way, but from the client end (EDM) the "fast" records all pause for ~0.5 sec whenever the waveforms push out their CA updates.
The ai's are already being processed at a higher priority, but this doesn't seem to help their updates get pushed out with higher priority.
Is there some tinkering I can do with the priorities of the CA threads to get what I want? How can I tell which thread will get which record updates? Is there something more obvious I'm missing?
--Brian
The CA thread pairs on the server (IOC) are created per client.
The client can set the priority as an argument to the ca_create_channel() call [1]. If the client-set priorities are honored on the server depends on the server side OS and/or configuration.
On real-time Linux, the MCoreUtils module [2] (EPICS 3.15 only) contains a rule-based engine to tinker with IOC thread priorities and policies.
Cheers,
~Ralph
[1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#ca_create_channel
[2] http://epics.sourceforge.net/mcoreutils/
Re: Prioritizing Channel Access per Record? Brian Bevins
Prev: Prioritizing Channel Access per Record? Brian Bevins
Next: NIKHEF hall probes Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Prioritizing Channel Access per Record? Brian Bevins
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
