1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Multiple Queries(on Sequencer and IOC)
To: [email protected]
Date: Tue, 18 Mar 2014 23:02:31 +0530
Dear All,
Kindly  help.
1. How to prevent sequencer from stop, when some PVs get disconnect(without making this a new state) and sequencer should be resumed when PV is available?
2. How to check if particular PV is connected, in sequencer?
3.  How to run multiple ioc(it may be soft or hard, having sequencer program ) on a single linux machine(Fedora 19).
I am getting warning when running multiple IOC machine. similar to ...
cas warning : configure TCP port was unavailable
cas warning : using dynamically assigned TCP port 56892
cas warning : but now two or more severs share the same UDP port
cas warning : Depending on your IP kernel this server may not be
cas warning : reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
I found some mail trail online but could  not get straight way. I also tried by putting firewall off.
4. How to monitor a passive record even it has same value after update.(as camonitor do not show/reflected same value update in pv ).
I am using
Epics base-3.14.12.3
Sequencer seq-2.1.16
OS: Linux Fedora 19  64bit
I have following settings.
export EPICS_ROOT=/home/ganesh/epics
export EPICS_HOST_ARCH=linux-x86_64
export EPICS_BASE=$EPICS_ROOT/base-3.14.12.3
export EPICS_EXTENSIONS=$EPICS_ROOT/extensions
export EPICS_CA_ADDR_LIST="192.168.8.2 192.168.8.3 192.168.8.4 192.168.8.5"
export MOTIF_LIB=/usr/lib64/
export SEQ=$EPICS_ROOT/extensions/seq-2.1.16
export PATH=/sbin:/bin:/usr/sbin:/usr/bin:$file:$EPICS_ROOT/base-3.14.12.3/bin/linux-x86_64:/bin/linux-x86_64
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
Thanks and Regards
Ganesh
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
Prev: Re: Prioritizing Channel Access per Record? Andrew Johnson
Next: css bundles issues Chen Xue
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: NIKHEF hall probes Pierrick Hanlet
Next: Multiple Queries(on Sequencer and IOC) Ganesh Jangir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
