1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Prioritizing Channel Access per Record?
To: <[email protected]>
Date: Tue, 18 Mar 2014 12:14:21 -0500
On 03/18/2014 12:00 PM, Ralph Lange wrote:
> Please check that you have no database links that would pull "fast" and
> "slow" records into the same lock set.
The IOC shell 'dblsr' command shows you the IOC's lock-sets.
'dblsr * 1' will print all the lock-sets and their members, while 'dblrs
* 2' shows you the links between the records as well. Unfortunately the
output is a bit noisy. You can use a specific record name instead of the
* to see just the lock-set containing that record.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Prioritizing Channel Access per Record? Brian Bevins
RE: Prioritizing Channel Access per Record? Mark Rivers
Re: Prioritizing Channel Access per Record? Brian Bevins
Re: Prioritizing Channel Access per Record? Ralph Lange
Prev: Re: Prioritizing Channel Access per Record? Brian Bevins
Next: Multiple Queries(on Sequencer and IOC) Ganesh Jangir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Prioritizing Channel Access per Record? Ralph Lange
Next: Re: Prioritizing Channel Access per Record? Brian Bevins
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
