1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS BOY and 16-bit Images
To: [email protected]
Date: Thu, 20 Mar 2014 15:44:02 +0100
Hi all,
I use an Intensity Graph widget in a CSS-BOY opi, to show a
preview of the images collected by an Andor camera using AreaDetector.
The images are 16 bit gray level ones (ranging from 0 to 65535).
The widget is connected with a PV (ArrayData) that is the
same I use with the ImageJ plugin distributed with AreaDetector.
The problem is that the widget displays correctly only the pixels
with gray levels < 32767 and interpret grater gray values as negative
numbers (16th bit =1).
On the contrary, ImageJ displays correctly he entire image.
Is there any way to overcome this problem with the BOY widget ?
Thank you,
Gabriele Salvato
RE: CSS BOY and 16-bit Images Hu, Yong
Prev: Re: softIOC through network file system Jeong Han Lee
Next: Re: Prioritizing Channel Access per Record? Brian Bevins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: CSS BOY and 16-bit Images Hu, Yong
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
