1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS BOY and 16-bit Images
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 20 Mar 2014 19:36:31 +0000
Hi Gabriele,
Before we conclude that the problem is related to BOY, please use "caget your_image_pv" (or caget -#number your_image_pv) to see what kind of image data you really get. If you find the data really containing negative values such as "-1" (I saw this kind of image data when I worked on Prosilica GigE camera), probably your camera is not properly configured through the AreaDetector driver.
If you are sure the image data are all OK with the range you expect (i.e. [0, 65535]), I guess the problem is most likely related to the configuration of the BOY Intensity Graph. Make sure you configure the following properties of the BOY Intensity Graph appropriately based on your camera configuration: Data Height, Data Width, Maximum, Minimum, Color Map, etc.
Give us more info such as your CSS version, image snapshots of the BOY & ImageJ, result of "caget your_image_pv".
Yong
From: [email protected] [[email protected]] on behalf of Gabriele Salvato [[email protected]]
Sent: Thursday, March 20, 2014 10:44 AM
To: [email protected]
Subject: CSS BOY and 16-bit Images
Hi all,
I use an Intensity Graph widget in a CSS-BOY opi, to show a
preview of the images collected by an Andor camera using AreaDetector.
The images are 16 bit gray level ones (ranging from 0 to 65535).
The widget is connected with a PV (ArrayData) that is the
same I use with the ImageJ plugin distributed with AreaDetector.
The problem is that the widget displays correctly only the pixels
with gray levels < 32767 and interpret grater gray values as negative
numbers (16th bit =1).
On the contrary, ImageJ displays correctly he entire image.
Is there any way to overcome this problem with the BOY widget ?
Thank you,
Gabriele Salvato
RE: CSS BOY and 16-bit Images Mark Rivers
CSS BOY and 16-bit Images Gabriele Salvato
Prev: RE: using C# dll's Mark Rivers
Next: RE: CSS BOY and 16-bit Images Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CSS BOY and 16-bit Images Gabriele Salvato
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
