1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS BOY and 16-bit Images
To: "Hu, Yong" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 20 Mar 2014 19:43:16 +0000
The problem is that EPICS CA does not have native unsigned data types.  For efficiency 16-bit image data normally uses a waveform record with FTVL=SHORT.  areaDetector has an ancillary PV that indicates whether the waveform is epicsInt16 or epicsUInt16.  CSS BOY should be using this PV to determine how to display the data.
From: [email protected] [[email protected]] on behalf of Hu, Yong [[email protected]]
Sent: Thursday, March 20, 2014 2:36 PM
To: [email protected]; [email protected]
Hi Gabriele,
Before we conclude that the problem is related to BOY, please use "caget your_image_pv" (or caget -#number your_image_pv) to see what kind of image data you really get. If you find the data really containing negative values such as "-1" (I saw this kind of image data when I worked on Prosilica GigE camera), probably your camera is not properly configured through the AreaDetector driver.
If you are sure the image data are all OK with the range you expect (i.e. [0, 65535]), I guess the problem is most likely related to the configuration of the BOY Intensity Graph. Make sure you configure the following properties of the BOY Intensity Graph appropriately based on your camera configuration: Data Height, Data Width, Maximum, Minimum, Color Map, etc.
Give us more info such as your CSS version, image snapshots of the BOY & ImageJ, result of "caget your_image_pv".
Yong
From: [email protected] [[email protected]] on behalf of Gabriele Salvato [[email protected]]
Sent: Thursday, March 20, 2014 10:44 AM
Subject: CSS BOY and 16-bit Images
Hi all,
I use an Intensity Graph widget in a CSS-BOY opi, to show a
preview of the images collected by an Andor camera using AreaDetector.
The images are 16 bit gray level ones (ranging from 0 to 65535).
The widget is connected with a PV (ArrayData) that is the
same I use with the ImageJ plugin distributed with AreaDetector.
The problem is that the widget displays correctly only the pixels
with gray levels < 32767 and interpret grater gray values as negative
numbers (16th bit =1).
On the contrary, ImageJ displays correctly he entire image.
Is there any way to overcome this problem with the BOY widget ?
Thank you,
Gabriele Salvato
RE: CSS BOY and 16-bit Images Mark Rivers
CSS BOY and 16-bit Images Gabriele Salvato
RE: CSS BOY and 16-bit Images Hu, Yong
Prev: RE: CSS BOY and 16-bit Images Hu, Yong
Next: Value of a record 'soon after' the IOC's initialization Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: CSS BOY and 16-bit Images Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
