1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Cross build/compilation - target only question
Date: Fri, 21 Mar 2014 03:11:59 +0000
Hi all,
I recently installed mingw32-gcc  mingw32-gcc-c++ (onto CentOS 6.4 x86_64) and copied the
CONFIG/CONFIG_SITE linux-x86_64.win32-x86-mingw files from base-3.15.0.1 into base-3.14.12.4
and successfully cross built base, asyn, seq and autosave, the only hassle being base including
Winver.h instead of winver.h. Okay so far so good.
But because the host linux-x86_64 architecture is built as well as the target win32-x86-mingw
architecture, when I tried to cross build an IOC, the linux-x86_64 part failed because it
can't find the include file "windows.h".
So my question is this: When I build an IOC, is there any easy way to only do the cross
compilation and skip the host build? (I'm not worried about the base host build - it works ;).
I'm sure I read about this in tech-talk last year but when I searched I didn't find anything.
Regards
Andrew C. Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
Re: Cross build/compilation - target only question Andrew Johnson
Prev: Value of a record 'soon after' the IOC's initialization Emmanuel Mayssat
Next: [no subject] Azra Jabeen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Cross build/compilation - target only question Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
