1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: using C# dll's
To: Bertrand Alain Gregor <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 21 Mar 2014 17:55:53 +0000
Hello Mark and Alain,
    Thank you very much for the examples.  I'll take a look at them and see what I can make of them.  I'm sure that I'll have more questions at some point.
Chris Roehrig
Sent: Friday, March 21, 2014 2:57 AM
To: Roehrig, Christian; EPICS Tech-Talk
Hi Chris,
Here at PSI we developed a whole .NET / C# EPICS stack both the client
and a server. The EPICS server would be seen as a normal IOC for any
client, while on the C# side you can define your PV, define scan rates
and feed the PV with any C# value.
You can see under "Server Library" the example
https://sourceforge.net/p/epicssharp/wiki/Home/
If you are interested, you can either pick the library pre-compiled with
nuget (included in VS 2013) or you can download the full source from
Sourceforge.
Sincerely,
Alain Bertrand
-----Original Message-----
[mailto:[email protected]] On Behalf Of Christian Roehrig
Sent: Thursday, March 20, 2014 17:31
To: EPICS Tech-Talk
Subject: using C# dll's
Hello,
     My group is contemplating purchasing a piece of equipment where the
vendor provides an SDK with dlls written in C#.  I don't really know
much about C#.  Has anyone tried to use C# in epics device support
before?  I assume I would have to wrap the API calls in a C++
application.  It would be great if I could look at an example. Thank
you.
Chris
using C# dll's Christian Roehrig
RE: using C# dll's Bertrand Alain Gregor
Prev: Re: Cross build/compilation - target only question Andrew Johnson
Next: VxWorks VME Ctrl-X vs. Power Cycle Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: using C# dll's Bertrand Alain Gregor
Next: RE: using C# dll's Russ Berg
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
