1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing EPICS on the Raspberry Pi
To: Pete Jemian <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 2 Apr 2014 09:14:10 +0200
On 3/17/14 5:29 PM, Pete Jemian wrote:
--- /bin/
+++ /bin/bash
Regarding the environment variable assignment, a cautious approach is to choose whether to define or extend the previous definition.  Here is one way in /bin/bash:
    if [ "" = "${LD_LIBRARY_PATH}" ]; then
        export LD_LIBRARY_PATH=${EPICS_BASE_LIB}
    else
        export LD_LIBRARY_PATH=${EPICS_BASE_LIB}:${LD_LIBRARY_PATH}
    fi
the documentation is now updated:  http://prjemian.github.io/epicspi/
Side Note:
  To be honest, we don't need the Yoda approach in a shell script.
  For the shell enthusiasts: We could simply write
    if [ "$LD_LIBRARY_PATH" ]; then
        export LD_LIBRARY_PATH=$EPICS_BASE_LIB
    else
        export LD_LIBRARY_PATH=$EPICS_BASE_LIB:$LD_LIBRARY_PATH
    fi
Thanks for the excellent instructions!
I needed another tweek in  xxx-5-6/xxxApp/src/Makefile:
This line must be commented out:
xxx_Common_LIBS += ip
I made a shell script, which does everything in one go, see below.
On the long run it may show up on github or so.
#!/bin/sh
BASHRC=~/.bashrc
BASH_ALIAS_EPICS=~/.epics
#Where is the source code of EPICS
HOME_EPICS_APPS=$HOME/../epics/Apps
#Where are the binaries of EPICS
EPICS_ROOT=/usr/local/epics
EPICS_BASE=$EPICS_ROOT/base
EPICS_MODULES=$EPICS_ROOT/modules
#Version of base
EPICS_BASE_VER=3.14.12.3
#Version for ASYN
ASYNVER=asyn4-22
#Version for synApps
SYNAPPSVER=synApps_5_6
#extensions top
EPICS_EXTENSIONS_TOP_VER=extensionsTop_20120904
#msi
EPICS_MSI_VER=msi1-5
export EPICS_ROOT EPICS_BASE EPICS_MODULES EPICS_BASE_VER HOME_EPICS_APPS
export EPICS_EXT=${EPICS_ROOT}/extensions
#apt or yum or port
if uname -a | egrep "CYGWIN|MING" >/dev/null; then
  SUDO=
else
  SUDO=sudo
fi
APTGET=/bin/false
if type apt-get >/dev/null 2>/dev/null; then
  APTGET="$SUDO apt-get install"
fi
if type yum >/dev/null 2>/dev/null; then
  APTGET="$SUDO /usr/bin/yum install"
fi
# port (Mac Ports)
if test -x /opt/local/bin/port; then
  APTGET="$SUDO port install"
fi
export APTGET
if ! test -d $HOME_EPICS_APPS; then
  $SUDO mkdir -p $HOME_EPICS_APPS || {
    echo >&2 can not chown $HOME_EPICS_APPS
    exit 1
fi
if ! test -w $HOME_EPICS_APPS; then
  $SUDO chown "$USER" $HOME_EPICS_APPS || {
    exit 1
fi
if test -L $EPICS_ROOT; then
    cd /usr/local &&
    epicsbaselink=$(readlink epics) &&
    #echo epicsbaselink=$epicsbaselink
    if test "$epicsbaselink" != "$HOME_EPICS_APPS"; then
      echo "$epicsbaselink" != "$HOME_EPICS_APPS" &&
      echo $SUDO rm $HOME_EPICS_APPS &&
      $SUDO rm $PWD/epics &&
      echo $SUDO ln -s $HOME_EPICS_APPS epics &&
      $SUDO ln -s $HOME_EPICS_APPS epics || {
        echo >&2 can not unlink $HOME_EPICS_APPS
        exit 1
    fi
else
  if test -e $EPICS_ROOT; then
    echo >&2 $EPICS_ROOT not a softlink
    echo >&2 $EPICS_ROOT please remove it
    exit 1
  fi
  cd /usr/local &&
    exit 1
fi
install_re2c()
  cd $HOME_EPICS_APPS &&
  if ! test -d re2c-code-git; then
    git clone git://git.code.sf.net/p/re2c/code-git re2c-code-git.tmp.$$ &&
    mv re2c-code-git.tmp.$$  re2c-code-git
  fi &&
    cd re2c-code-git/re2c &&
    ./autogen.sh &&
    ./configure &&
    make &&
    echo PWD=$PWD $SUDO make install &&
    $SUDO make install
  if ! test -e baseR${EPICS_BASE_VER}.tar.gz; then
    wget http://www.aps.anl.gov/epics/download/base/baseR${EPICS_BASE_VER}.tar.gz -O baseR${EPICS_BASE_VER}.tar.gz.$$ &&
    mv baseR${EPICS_BASE_VER}.tar.gz.$$ baseR${EPICS_BASE_VER}.tar.gz || {
      echo >&2 can not wget baseR${EPICS_BASE_VER}.tar.gz
      exit 1
  fi
  if ! test -d base-$EPICS_BASE_VER; then
    tar xzf baseR${EPICS_BASE_VER}.tar.gz || {
      echo >&2 can not tar xzf baseR${EPICS_BASE_VER}.tar.gz
      rm -rf base-$EPICS_BASE_VER
      exit 1
  fi &&
  if ! test -L base; then
    echo ln -s ./base-${EPICS_BASE_VER} ./base &&
    ln -s ./base-${EPICS_BASE_VER} ./base || {
      exit 1
  fi
) || exit 1
EPICS_HOST_ARCH=$($EPICS_ROOT/base/startup/EpicsHostArch) || {
  echo >&2 EPICS_HOST_ARCH failed
  exit 1
# here we know the EPICS_HOST_ARCH
EPICS_BASE_BIN=${EPICS_BASE}/bin/$EPICS_HOST_ARCH
EPICS_EXT_BIN=${EPICS_EXT}/bin/$EPICS_HOST_ARCH
PATH=$PATH:$EPICS_BASE_BIN:$EPICS_EXT_BIN
EPICS_EXT_LIB=${EPICS_EXT}/lib/$EPICS_HOST_ARCH
if test "${LD_LIBRARY_PATH}"; then
  export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE_LIB
else
  export LD_LIBRARY_PATH=$EPICS_EXT_LIB
fi
echo PATH=$PATH
export EPICS_BASE_BIN EPICS_EXT EPICS_EXT_LIB EPICS_EXT_BIN PATH LD_LIBRARY_PATH
############# Fix bashrc (or friends)
if ! grep "$BASH_ALIAS_EPICS" $BASHRC >/dev/null; then
  echo updating $BASHRC
  cat <<EOF >>$BASHRC
#install-epics.sh
if test -r ${BASH_ALIAS_EPICS}; then
. ${BASH_ALIAS_EPICS}
fi
EOF
fi
if ! test -e ${BASH_ALIAS_EPICS}; then
  echo creating en empty ${BASH_ALIAS_EPICS}
  touch ${BASH_ALIAS_EPICS}
fi
if ! grep EPICS_EXT_LIB ${BASH_ALIAS_EPICS} >/dev/null; then
  echo updating ${BASH_ALIAS_EPICS}
  cat >>${BASH_ALIAS_EPICS} <<EOF
export EPICS_ROOT=$EPICS_ROOT
export EPICS_BASE=\$EPICS_ROOT/base
export EPICS_EXT=\${EPICS_ROOT}/extensions
export EPICS_HOST_ARCH=$($EPICS_BASE/startup/EpicsHostArch)
export EPICS_EXT_BIN=${EPICS_EXT}/bin/\$EPICS_HOST_ARCH
export EPICS_EXT_LIB=${EPICS_EXT}/lib/\$EPICS_HOST_ARCH
export EPICS_MODULES=\$EPICS_ROOT/modules
export EPICS_BASE_BIN=\${EPICS_BASE}/bin/\$EPICS_HOST_ARCH
export EPICS_BASE_LIB=\${EPICS_BASE}/lib/\$EPICS_HOST_ARCH
export LD_LIBRARY_PATH=\${EPICS_BASE_LIB}:\$LD_LIBRARY_PATH
if test "\$LD_LIBRARY_PATH"; then
  export LD_LIBRARY_PATH=\$LD_LIBRARY_PATH:\$EPICS_BASE_LIB
else
  export LD_LIBRARY_PATH=\$EPICS_EXT_LIB
fi
export PATH=\$PATH:\$EPICS_BASE_BIN:\$EPICS_EXT_BIN
EOF
fi
if ! test -e $HOME_EPICS_APPS/base/makeok; then
  # We need g++
  if ! type g++ >/dev/null 2>/dev/null; then
    echo $APTGET g++
    $APTGET g++
  fi &&
  #We need readline
  # Mac OS: /usr/include/readline/readline.h
  # Linux: /usr/include/readline.h
  if ! test -r /usr/include/readline/readline.h; then
    test -r /usr/include/readline.h ||
    $APTGET readline-devel ||
    $APTGET libreadline-dev ||
      echo >&2 can not install readline-devel
      exit 1
  fi
    echo make in $HOME_EPICS_APPS/base &&
    cd $HOME_EPICS_APPS/base &&
    make && touch makeok || {
      echo >&2 make failed in $PWD
      exit 1
  ) || exit 1
else
  echo The file $HOME_EPICS_APPS/base/makeok exist, skipping make
fi
#Modules
  cd $HOME_EPICS_APPS/ &&
  if ! test -d modules; then
    mkdir modules
  fi
) || exit 1
#synApps
if test -n "$SYNAPPSVER"; then
    if ! test -e $SYNAPPSVER.tar.gz; then
      wget http://www.aps.anl.gov/bcda/synApps/tar/$SYNAPPSVER.tar.gz -O $SYNAPPSVER.tar.gz.$$ &&
      mv $SYNAPPSVER.tar.gz.$$ $SYNAPPSVER.tar.gz || {
        echo >&2 can not wget $SYNAPPSVER.tar.gz
        exit 1
    fi &&
    if ! test -d $SYNAPPSVER; then
      tar xzvf $SYNAPPSVER.tar.gz
    fi
    echo >&2 failed tar xzvf $SYNAPPSVER.tar.gz in $PWD
    exit 1
    cd $HOME_EPICS_APPS/synApps_5_6/support/configure &&
      if ! test -e RELEASE.orig; then
        cp -v RELEASE RELEASE.orig || exit 1
      fi &&
      sed <RELEASE.orig >/tmp/$$ \
        -e "s!^SUPPORT=.*!SUPPORT=$EPICS_ROOT/synApps_5_6/support!" \
        -e "s!^EPICS_BASE=.*!EPICS_BASE=$EPICS_ROOT/base!" &&
      mv -fv /tmp/$$ RELEASE
      echo >&2 failed RELEASE in $PWD
      exit 1
      mkdir -p orig || {
        echo >&2 failed mkdir -p orig in $PWD
        exit 1
      for f in EPICS_BASE.cygwin-x86 EPICS_BASE.linux-x86 EPICS_BASE.linux-x86_64 EPICS_BASE.win32-x86 EPICS_BASE.windows-x64 SUPPORT.cygwin-x86  SUPPORT.linux-x86  SUPPORT.linux-x86_64  SUPPORT.win32-x86  SUPPORT.windows-x64; do
        if test -e "$f"; then
          mv -v "$f" $PWD/orig/ || {
            echo >&2 failed mv "$f" orig/ in $PWD
            exit 1
        fi
      done
      echo cd $HOME_EPICS_APPS/synApps_5_6/support &&
      if ! test -e makereleaseok; then
        make release && touch makereleaseok || {
          echo >&2 failed make release in $PWD
          exit 1
      else
        echo The file $PWD/makereleaseok exist, skipping make release
      fi
      if ! test -e Makefile.orig; then
        cp -v Makefile Makefile.orig || exit 1
      fi &&
      cp -v Makefile.orig Makefile &&
      for mod in ALLEN_BRADLEY DAC128V IP330 IPUNIDIG LOVE IP VAC SOFTGLUE QUADEM DELAYGEN CAMAC VME AREA_DETECTOR DXP; do
        echo removing $mod in $PWD/Makefile &&
        sed -e "s/ $mod / /g" -e "s/ $mod\$/ /g" <Makefile >Makefile.tmp.$$ &&
        ! diff Makefile Makefile.tmp.$$ >/dev/null &&
        mv -f Makefile.tmp.$$ Makefile ||{
          echo >&2 failed removing $mod in $PWD
          exit 1
      done &&
        # Remove AREA_DETECTOR and IP from RELEASE
        cd xxx-5-6/configure &&
        fi &&
        sed <RELEASE.orig >RELEASE.tmp.$$ \
          -e "s!^AREA_DETECTOR!#AREA_DETECTOR!" \
          -e "s!^IP=!#IP=!" &&
        mv -fv RELEASE.tmp.$$ RELEASE
        # Remove AREA_DETECTOR and IP from dbd
        cd xxx-5-6/xxxApp/src &&
        if ! test -e xxxCommonInclude.dbd.orig; then
          cp -v xxxCommonInclude.dbd xxxCommonInclude.dbd.orig || exit 1
        fi &&
        sed <xxxCommonInclude.dbd.orig >xxxCommonInclude.dbd.tmp.$$ \
          -e "s!\(include.*ipSupport.dbd\)!#\1!" &&
        mv -fv xxxCommonInclude.dbd.tmp.$$ xxxCommonInclude.dbd
        # Remove AREA_DETECTOR related modules from Makefile
        fi &&
        cp Makefile.orig Makefile &&
        for mod in ADSupport NDPlugin simDetector netCDF dxp "xxx_Common_LIBS += ip"; do
          sed -e "s/\(.*$mod.*\)/#XXX Removed by install-epics.sh XXX  \1/g" <Makefile >Makefile.tmp.$$ &&
          mv -f $PWD/Makefile.tmp.$$ $PWD/Makefile ||{
            exit 1
        done
      echo >&2 failed in $PWD
      exit 1
      cd $HOME_EPICS_APPS/modules &&
      if ! test -d motor; then
        ln -sv ../synApps_5_6/support/motor-6-7/ motor || {
        echo >&2 Can not ln -sv ../synApps_5_6/support/motor-6-7/ motor
        exit 1
      fi
    exit 1
  if test "$EPICS_EXTENSIONS_TOP_VER"; then
      if ! test -e $EPICS_EXTENSIONS_TOP_VER.tar.gz; then
        echo installing $EPICS_EXTENSIONS_TOP_VER &&
        wget http://www.aps.anl.gov/epics/download/extensions/$EPICS_EXTENSIONS_TOP_VER.tar.gz -O $EPICS_EXTENSIONS_TOP_VER.tar.gz.$$ &&
        mv $EPICS_EXTENSIONS_TOP_VER.tar.gz.$$ $EPICS_EXTENSIONS_TOP_VER.tar.gz || {
          echo >&2 can not wget $EPICS_EXTENSIONS_TOP_VER.tar.gz
          exit 1
      fi
      if ! test -d ${EPICS_EXTENSIONS_TOP_VER}; then
        tar xzf $EPICS_EXTENSIONS_TOP_VER.tar.gz
      fi
  fi &&
  if ! type re2c >/dev/null 2>/dev/null; then
    echo $APTGET re2c
    $APTGET re2c || install_re2c
  fi &&
  if test "$EPICS_MSI_VER"; then
      if ! test -e $EPICS_MSI_VER.tar.gz; then
        echo installing $EPICS_MSI_VER &&
        wget http://www.aps.anl.gov/epics/download/extensions/$EPICS_MSI_VER.tar.gz -O $EPICS_MSI_VER.tar.gz.$$ &&
        mv $EPICS_MSI_VER.tar.gz.$$ $EPICS_MSI_VER.tar.gz || {
          echo >&2 can not wget $EPICS_MSI_VER.tar.gz
          exit 1
      fi &&
      if ! test -e extensions/src/$EPICS_MSI_VER/makeok; then
          mkdir -p extensions/src &&
          cd extensions/src &&
          tar xzf ../../$EPICS_MSI_VER.tar.gz &&
          cd $EPICS_MSI_VER &&
            exit 1
          echo >&2 msi failed in $PWD
          exit 1
      else
        echo The file extensions/src/$EPICS_MSI_VER/makeok exist, skipping make
      fi
  fi &&
    if ! test -e makeok; then
      make release || {
        echo >&2 PWD=$PWD failed make release
        exit 1
      make rebuild && touch makeok || {
        echo >&2 PWD=$PWD failed make rebuild
        echo >&2 PATH=$PATH
        exit 1
    else
      echo The file $PWD/makeok exist, skipping make
    fi
    echo >&2 failed $SYNAPPSVER PWD=$PWD PATH=$PATH
    exit 1
else
  echo SYNAPPSVER not defined, skipping synApps
fi
if test -n "$ASYNVER"; then
    if ! test -d asyn; then
      ln -sv  ../asyn4-22/ asyn || {
        echo >&2 Can not ln -sv ../asyn4-22/ asyn
        exit 1
    fi
    if ! test -e $ASYNVER.tar.gz; then
      wget http://www.aps.anl.gov/epics/download/modules/$ASYNVER.tar.gz -O $ASYNVER.tar.gz.$$ &&
      mv $ASYNVER.tar.gz.$$ $ASYNVER.tar.gz || {
        echo >&2 can not wget $ASYNVER.tar.gz
        exit 1
    fi
    if ! test -d $ASYNVER; then
      tar xzvf $ASYNVER.tar.gz
    fi
    cd $HOME_EPICS_APPS/$ASYNVER/configure && {
      fi
        -e "s!^EPICS_BASE=.*!EPICS_BASE=$EPICS_ROOT/base!" \
        -e 's!^IPAC=!#IPAC=!' \
        -e 's!^SNCSEQ=!#SNCSEQ=!' &&
      mv -vf /tmp/$$ RELEASE
    if ! test -e $HOME_EPICS_APPS/$ASYNVER/makeok; then
        cd $HOME_EPICS_APPS/$ASYNVER &&
          exit 1
    else
      echo The file $HOME_EPICS_APPS/$ASYNVER/makeok exist, skipping make
    fi
    echo >&2 failed $ASYNVER
    exit 1
else
  echo ASYNVER not defined, skipping asyn
fi
Re: Installing EPICS on the Raspberry Pi Torsten Bögershausen
Installing EPICS on the Raspberry Pi Pete Jemian
Re: Installing EPICS on the Raspberry Pi Pete Jemian
Prev: Re: build question Stephen Beckwith
Next: Re: Multiple IOCs on one Linux host Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing EPICS on the Raspberry Pi Pete Jemian
Next: Re: Installing EPICS on the Raspberry Pi Torsten Bögershausen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
