1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS : Multiple IOC pv(s) disconnect on ethernet unplug
To: Sud Roy <[email protected]>
Date: Fri, 4 Apr 2014 13:57:36 -0400
Hi:
I believe this is related to the general multiple-IOCs-on-same-computer problem, https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Configure_Channel_Access
With
 EPICS_CA_ADDR_LIST = IP-of-that-server
you only get the IOC that was started last.
Same with
 EPICS_CA_ADDR_LIST = 127.0.0.1
You get the local IOC that was started last on the local computer.
You must use
 EPICS_CA_ADDR_LIST = broadcast-address-that-includes-that-server
to get all IOCs that are running on a computer.
With
 EPICS_CA_ADDR_LIST = "127.0.0.1 broadcast-address-that-includes-myself"
you get all IOCs on the local computer, but it's likely going 'over the network', even for the local IOC, since it would only find one of them via 127.0.0.1.
If the network cable is disconnected, I'm not sure if you might still be able to reach yourself via your own network interface.
Maybe the network kernel somehow decides that the interface is not connected, so it can't "work", and also doesn't handle broadcasts from the local computer to the local network interface?
-Kay
On Apr 4, 2014, at 1:37 PM, Sud Roy <[email protected]<mailto:[email protected]>> wrote:
Hi Everyone,
I am using two IOC(s) on same system and able to get pv data from both IOC on system and over network as well.
I am using CSS ( Control system studio) for GUI on same system, able to get/set pv value from it.
Trouble arises when I unplug ethernet cable from my system running these two IOC(s),immediately all CSS widgets shows "disconnected" .
I already configured CSS Channel addr list to "auto", else added "localhost" on the list (though checked auto addr list check box) ,same I did for EPICS environment variables .
Is there anything else has to be done so that even on ethernet unplug all pv(s) from both IOC would survive on CSS ?
Please guide if am missing something or configured CSS or EPICS incorrectly.
Thank you.
Best regards,
Sudeep Roy
Re: CSS : Multiple IOC pv(s) disconnect on ethernet unplug Ralph Lange
CSS : Multiple IOC pv(s) disconnect on ethernet unplug Sud Roy
Prev: CSS : Multiple IOC pv(s) disconnect on ethernet unplug Sud Roy
Next: areaDetector R2-0 released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CSS : Multiple IOC pv(s) disconnect on ethernet unplug Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
