1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Building Base on win64...
Date: Tue, 8 Apr 2014 18:58:20 +0000
Hello…
I’m trying to build EPICS baseR3.14.12.4 on a windows64 machine, and I’ve run into the following issue:
link /nologo /subsystem:windows /dll /MANIFEST /LTCG /incremental:no /opt:ref /r
elease /version:3.14 /MACHINE:X64     /implib:Com.lib /out:Com.dll          buck
etLib.obj epicsRingPointer.obj epicsRingBytes.obj postfix.obj calcPerform.obj cv
tFast.obj resourceLib.obj epicsOnce.obj epicsSingletonMutex.obj dbmf.obj ellLib.
obj envSubr.obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj fdmgr.obj fdM
anager.obj freeListLib.obj gpHashLib.obj iocsh.obj registry.obj libComRegister.o
bj iocLog.obj logClient.obj macCore.obj macEnv.obj macUtil.obj aToIPAddr.obj adj
ustment.obj cantProceed.obj epicsConvert.obj epicsExit.obj epicsStdlib.obj epics
String.obj truncateFile.obj ipAddrToAsciiAsynchronous.obj epicsUnitTest.obj epic
sThread.obj epicsMutex.obj epicsEvent.obj epicsTime.obj epicsMessageQueue.obj ep
icsMath.obj epicsGeneralTime.obj osiClockTime.obj osdSock.obj osdSockAddrReuse.o
bj osiSock.obj systemCallIntMech.obj epicsSocketConvertErrnoToString.obj osdAsse
rt.obj osdFindSymbol.obj osdInterrupt.obj osdPoolStatus.obj osdSignal.obj osdEnv
.obj epicsReadline.obj epicsTempFile.obj epicsStdio.obj osdStdio.obj osdThread.o
bj osdMutex.obj osdEvent.obj osdTime.obj osdProcess.obj osdNetIntf.obj osdMessag
eQueue.obj devLibVME.obj devLibVMEOSD.obj taskwd.obj epicsTimer.obj timer.obj ti
merQueue.obj timerQueueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj
tsDefs.obj epicsGetopt.obj setThreadName.obj forceBadAllocException.obj Com.res
    ws2_32.lib advapi32.lib user32.lib
bucketLib.obj : fatal error LNK1112: module machine type 'X86' conflicts with ta
rget machine type 'x64'
../../../configure/RULES_BUILD:291: recipe for target 'Com.dll' failed
make[3]: *** [Com.dll] Error 88
make[3]: Leaving directory '/cygdrive/c/epics/base/src/libCom/O.windows-x64'
../../configure/RULES_ARCHS:63: recipe for target 'install.windows-x64' failed
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory '/cygdrive/c/epics/base/src/libCom'
../configure/RULES_DIRS:70: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory '/cygdrive/c/epics/base/src'
configure/RULES_DIRS:70: recipe for target 'src.install' failed
make: *** [src.install] Error 2
I have EPICS_HOST_ARCH set to windows-x64.
Any thoughts on what I may be doing wrong?  Thanks…
Dave
David Reid
Software Engineer, Behavior
Description: C:\AllenInstitute_Email_signature_html_6e825420.png
www.alleninstitute.org
Re: Building Base on win64... Andrew Johnson
RE: Building Base on win64... Mark Rivers
Prev: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mark Rivers
Next: Re: Building Base on win64... Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: autosave 5.3 Mooney, Tim M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
