Hi David,
On 04/08/2014 01:58 PM, David Reid wrote:
> I’m trying to build EPICS baseR3.14.12.4 on a windows64 machine, and
> I’ve run into the following issue:
> link /nologo /subsystem:windows /dll /MANIFEST /LTCG /incremental:no
> /opt:ref /release /version:3.14 /MACHINE:X64 /implib:Com.lib
> /out:Com.dll bucketLib.obj epicsRingPointer.obj epicsRingBytes.obj postfix.obj
> bucketLib.obj : fatal error LNK1112: module machine type 'X86' conflicts
> with target machine type 'x64'
> I have EPICS_HOST_ARCH set to windows-x64.
> Any thoughts on what I may be doing wrong? Thanks…
From the error message and the above command-line it appears that at
least one of your .obj files was compiled for the 32-bit architecture,
but you're trying to link it into a 64-bit Com.dll.
I would start by running a 'make rebuild' command from the top of Base,
which should clean out the old .obj files and recompile them for x64. If
the same problem happens again, you must have done something strange in
base/configure files (or in your $(HOME)/configure directory). In that
case, please find and post the make output showing the compilation of
the bucketLib.obj file, and describe what changes you've made to the
base/configure/os/*windows-x64* files.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Building Base on win64... David Reid
RE: Building Base on win64... Mark Rivers
<2014>
2025
2026
<2014>
2025
2026
