Hi Stuart,
You have not told the asynPortDriver base class that you will be using the asynUInt32Digital interface. You do that with the interfaceMask and interruptMask arguments to the ADDriver constructor.
Change this:
: ADDriver(portName, 1, NUM_FastCCD_DET_PARAMS, maxBuffers, maxMemory,
asynEnumMask, asynEnumMask,
ASYN_CANBLOCK, 1, priority, stackSize)
to this:
asynEnumMask | asynUInt32DigitalMask, asynEnumMask | asynUInt32DigitalMask,
From: [email protected] [[email protected]] on behalf of Wilkins, Stuart [[email protected]]
Sent: Tuesday, April 15, 2014 5:38 AM
To: [email protected]
Subject: Problem with UInt32Digital in Asyn
Hi All,
I am having a problem using the UInt32Digital type in ASYN. I am writing an areaDetector driver and have a camera that gives status back in 3 registers. I would like to read this value from the camera and put it into a UInt32Digital type so that I can make many records for all the status bits. In the constructor of the class I define:
createParam(FastCCDDCMStatusString,asynParamUInt32Digital,&FastCCDDCMStatus);
Then when I poll the camera I write the parameter using:
setUIntDigitalParam(FastCCDDCMStatus, dcm, 0xFFFF);
This works for all other parameters but not for this one. When the IOC boots, I get the rather cryptic message:
XF:23ID1-ES{Det-CCD}cam1:test devAsynUInt32Digital::initCommon findInterface asynUInt32DigitalType
I am sure this is most likely something stupid, but have drawn a blank to what it is. I would appreciate any help anyone has on getting this going. The code can be viewed at:
https://github.com/NSLS-II-CSX/ADFastCCD
Thanks!
Stuart
- Re: Problem with UInt32Digital in Asyn Wilkins, Stuart
- Problem with UInt32Digital in Asyn Wilkins, Stuart
RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
<2014>
2025
2026
<2014>
2025
2026
