1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: importing "org.csstudio.utility.pv" in BOY Jython scripts
Date: Tue, 15 Apr 2014 11:40:52 -0400
we have a quite large number of BOY OPI-s that use Jython scripts. These Jython scripts use "org.csstudio.utility.pv", namely PVFactory, so they contain the following line:
from org.csstudio.utility.pv import PVFactory
Until now we have been using basic EPICS CSS 3.1.7 build from SNS , and now we would like to use the recent version 3.2.16. But what happens now with that version is that Jython fails to find the "org.csstudio.utility.pv" on the line shown above. That plugin is incuded in the plugin directory, and when I explicitly append the jar-file to the sys.path, then the scripts work. At this time I do not want to go into each script file and add a line to append the jar file. Instead, I was wandering if I can recompile EPICS CSS from SNS source in such a way that I do not need to specify the "org.csstudio.utility.pv" path myself in the scripts. Just getting the source for 3.2.26 and making the "org.csstudio.basic.epics.product" produces the same result. Is there something simple that I need to change in Eclipse when building the product to have that jar-file included in the list
when Jython loads?
   Hovanes Egiyan.
PVManager Re: importing "org.csstudio.utility.pv" in BOY Jython scripts Kasemir, Kay
Prev: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mazanec Tomáš
Next: PVManager Re: importing "org.csstudio.utility.pv" in BOY Jython scripts Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with UInt32Digital in Asyn Wilkins, Stuart
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
