1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: multiple threads and ca_attach_context
To: "'[email protected]'" <[email protected]>
Date: Wed, 23 Apr 2014 00:14:32 +0000
Hi
I am unable to determine how to successfully use ca_attach_context, with the creation of multiple threads to read CA channels.
I suspect I have missed a step but do not find any relevant documentation.
This is all pertinent to EPICS R3.14.9
Any help would be appreciated.
Two scenarios:
1.     Open a connection, via caRepeater, and periodically read the same channel (no problems)
2.     Open a connection, via caRepeater, and periodically launch a posix thread to read the same channel (does not work). Each thread exits after getting a CA channel value.
Starting the connection  to caRepeater.
(code snippets are paraphrased somewhat):
      static  struct ca_client_context *ca_context = NULL;
      stat  = ca_context_create(ca_enable_preemptive_callback);
      ca_context = ca_current_context();
      stat = ca_add_exception_event( exception_callback, NULL );
      stat = ca_add_fd_registration( fdReg, NULL);
Now launch threads to obtain channel values, in my failure scenario each thread is accessing the same channel. The following occurs for the first thread.
// The following is done for both scenarios.
// Find the info for the specific channel – details not shown, but essentially an element in an array of structures.
If ( info->channelId == NULL ) {
   stat = ca_create_channel( ch_name, changeConnection_callback, info, 20, &info->channelId);
  // Do the following as ca_pend_io() returns immediately because a callback was registered with the channel creation.
   while ( ca_stateinfo->channelId) != cs_conn ) {  <a delay with overall timeout> }   // Completes without timeout.
The following is done for each thread (the non-threaded scenario effectively falls thru).
If ( ca_context == NULL )
// This never occurs, as expected, because ca_context was previously setup
else {
  my_context = ca_current_context();
  if ( my_context != ca_context ) {                   // my_context is always nil for each thread and equality for the non=threaded scenario
    stat = ca_attach_context( ca_context );  // This completes without error for each thread
The following is done whether or not threads are created (both scenarios):
stat = ca_get( info->getType, info->channelId, buff );  // This fails with ECA_DISCONN error status in the threaded scenario only.
Even with a 3 second delay after ca_get and then retrying ca_get, it fails with disconnected status, in the threaded scenario.
If a thread is not created then the above completes successfully (the ca_attach_context logic does not occur in that scenario).
Allan
RE: multiple threads and ca_attach_context Hill, Jeff
asyn/stream hang on (very long email, sorry in advance) Mauro Giacchini
Prev: Re: Help about creat Archive Engine Kasemir, Kay
Next: RE: multiple threads and ca_attach_context Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
