1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem building synApps on Windows...
Date: Thu, 24 Apr 2014 17:54:55 +0000
Hi…
I’m having an issue with building synApps on my windows-x64 machine.  I am running base3.14.12.4.  Here’s the error that I’m getting:
Creating library safeMonitor.lib and object safeMonitor.exp
Generating code
Finished generating code
"preprocessing ../userfunc.st"
cl /C /E             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPREC
ATE /D_CRT_NONSTDC_NO_DEPRECATE -I. -I../O.Common -I. -I.. -I../../../include/os
/WIN32 -I../../../include -Ic:\epics\base/include/os/WIN32 -Ic:\epics\base/inclu
de       ../userfunc.st > userfunc.i
userfunc.st
"converting userfunc.i"
../../../bin/windows-x64/snc.exe   +m -i  userfunc.i -o userfunc.c.tmp
perl -MExtUtils::Command -e mv userfunc.c.tmp userfunc.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MD     -I. -I..\\O.C
ommon -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -Ic:\epics
\base\\include\\os\\WIN32 -Ic:\epics\base\\include       userfunc.c
userfunc.c
link -nologo  /LTCG /incremental:no /opt:ref /release   /MACHINE:X64
-out:userfunc.exe        userfunc.obj seqSoftIoc_registerRecordDeviceDriver.obj
testSupport.obj      ..\\..\\..\\lib\\windows-x64\\seq.lib  ..\\..\\..\\lib\\wi
ndows-x64\\pv.lib  c:\epics\base\\lib\\windows-x64\\recIoc.lib  c:\epics\base\\l
ib\\windows-x64\\softDevIoc.lib  c:\epics\base\\lib\\windows-x64\\miscIoc.lib  c
:\epics\base\\lib\\windows-x64\\rsrvIoc.lib  c:\epics\base\\lib\\windows-x64\\db
toolsIoc.lib  c:\epics\base\\lib\\windows-x64\\asIoc.lib  c:\epics\base\\lib\\wi
ndows-x64\\dbIoc.lib  c:\epics\base\\lib\\windows-x64\\registryIoc.lib  c:\epics
\base\\lib\\windows-x64\\dbStaticIoc.lib  c:\epics\base\\lib\\windows-x64\\ca.li
b  c:\epics\base\\lib\\windows-x64\\Com.lib
   Creating library userfunc.lib and object userfunc.exp
Generating code
"preprocessing ../userfuncEf.st"
de       ../userfuncEf.st > userfuncEf.i
userfuncEf.st
"converting userfuncEf.i"
../../../bin/windows-x64/snc.exe   +m -i  userfuncEf.i -o userfuncEf.c.tmp
perl -MExtUtils::Command -e mv userfuncEf.c.tmp userfuncEf.c
\base\\include\\os\\WIN32 -Ic:\epics\base\\include       userfuncEf.c
userfuncEf.c
userfuncEf.c(13) : error C2016: C requires that a struct or union has at least o
ne member
../userfuncEf.st(26) : error C2059: syntax error : '}'
make[4]: *** [userfuncEf.obj] Error 2
make[4]: Leaving directory `c:/epics/synApps_5_7/support/seq-2-1-13/test/validat
e/O.windows-x64'
make[3]: *** [install.windows-x64] Error 2
make[3]: Leaving directory `c:/epics/synApps_5_7/support/seq-2-1-13/test/validat
e'
make[2]: *** [validate.install] Error 2
make[2]: Leaving directory `c:/epics/synApps_5_7/support/seq-2-1-13/test'
make[1]: *** [test.install] Error 2
make[1]: Leaving directory `c:/epics/synApps_5_7/support/seq-2-1-13'
make: *** [c:\epics\synApps_5_7\support/seq-2-1-13.install] Error 2
C:\epics\synApps_5_7\support>
Any hints would be very appreciated…Thanks…
Dave
David Reid
Software Engineer, Behavior
Description: C:\AllenInstitute_Email_signature_html_6e825420.png
www.alleninstitute.org
Re: Problem building synApps on Windows... Andrew Johnson
Prev: RE: asyn/stream hang on (very long email, sorry in advance) Mark Rivers
Next: Re: Problem building synApps on Windows... Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn/stream hang on (very long email, sorry in advance) Dirk Zimoch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
