1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem building synApps on Windows...
To: David Reid <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 24 Apr 2014 13:28:47 -0500
Hi David,
On 04/24/2014 12:54 PM, David Reid wrote:
> I’m having an issue with building synApps on my windows-x64 machine.  I
> am running base3.14.12.4.  Here’s the error that I’m getting:
This is actually a known problem in the 2.1.13 version of the sequencer
included with synApps 5.7 which has been fixed in later releases — see
http://www-csr.bessy.de/control/SoftDist/sequencer/KnownProblems.html#known-problems-in-release-2-1-13
You should be able to download the latest version 2.1.16 of the
sequencer from the BESSY website at
  http://www-csr.bessy.de/control/SoftDist/sequencer/Installation.html
and install that into your synApps tree instead. I assume synApps
provides documentation on how to do that.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Problem building synApps on Windows... David Reid
Prev: Problem building synApps on Windows... David Reid
Next: Re: asyn/stream hang on (very long email, sorry in advance) Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Area Detector build issues... David Reid
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
