1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Area Detector build issues...
Date: Fri, 25 Apr 2014 15:58:42 +0000
Hi everyone…
I’m trying to build Area Detector (along with asyn, autosave, busy, calc, and sscan) from the SynApps release on windows-x64, and have run into a problem.  The error is:
LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; use /NODEFAULTLIB:library
Generating code
Finished generating code
LIBCMT.lib(timeset.obj) : error LNK2005: __daylight already defined in MSVCRT.lib(MSVCR120.dll)
LIBCMT.lib(timeset.obj) : error LNK2005: __timezone already defined in MSVCRT.lib(MSVCR120.dll)
NeXus.dll : fatal error LNK1169: one or more multiply defined symbols found
make[4]: *** [NeXus.dll] Error 1169
make[4]: Leaving directory `c:/epics/synApps_5_7/support/areaDetector-1-9-1/ADApp/nexusSrc/O.windows-x64'
make[3]: *** [install.windows-x64] Error 2
make[3]: Leaving directory `c:/epics/synApps_5_7/support/areaDetector-1-9-1/ADApp/nexusSrc'
make[2]: *** [nexusSrc.install] Error 2
make[2]: Leaving directory `c:/epics/synApps_5_7/support/areaDetector-1-9-1/ADApp'
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory `c:/epics/synApps_5_7/support/areaDetector-1-9-1'
make: *** [c:\epics\synApps_5_7\support/areaDetector-1-9-1.install] Error 2
Thanks for any help….
Dave
David Reid
Software Engineer, Behavior
Description: C:\AllenInstitute_Email_signature_html_6e825420.png
www.alleninstitute.org
Re: Area Detector build issues... Mark Rivers
Prev: Re: asyn/stream hang on (very long email, sorry in advance) Dirk Zimoch
Next: Re: Area Detector build issues... Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem building synApps on Windows... Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
