1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PCMON segmentation fault
To: [email protected]
Date: Tue, 29 Apr 2014 09:40:12 +0200
Hi Nicoletta,
We are using this package all the time without problems. But I cannot say at the moment if the version we are using is exactly the same as the one on the download site. Maybe that one is old and not suitable for 64 bit. I have to check that. Also the developer of that software is not at PSI any more.
To run outside a debugger, do this before running the ioc:
ulimit -c unlimited
The run the ioc, let it crash and do a post-mortem analysis with the debugger and the core file created by the crash.
Dirk
On 28.04.2014 11:26, Nicoletta Petrella wrote:
Dear all,
I have downloaded the package PCMON from
http://epics.web.psi.ch/software/pcmon/, but If I try to run it I get a
segmentation fault while reading the memory status.
If I run the IOC inside the debugger I do not get any error and the
package works fine.
The problem apparently is in the devSysMon.c.
Reading the core file from the debugger I get:
Core was generated by `../../bin/linux-x86_64/pcMonitor st2.cmd'.
Program terminated with signal 11, Segmentation fault.
#0  meminfo () at ../devSysMon.c:437
437                    while(*p++ != '\n'); /* ignore lines we don't
understand */
Missing separate debuginfos, use: debuginfo-install
glibc-2.12-1.132.el6.x86_64 libgcc-4.4.7-4.el6.x86_64
libstdc++-4.4.7-4.el6.x86_64 ncurses-libs-5.7-3.20090208.el6.x86_64
readline-6.0-4.el6.x86_64
(gdb)
If I cut from the database all the records related to the Memory Status
which use the MEMLoad device, the package works fine.
Did anyone have the same problem? Would you know how to run the IOC
outside the debugger without getting a segmentation fault?
Thank you very much.
Kind regards,
Nicoletta
..0==/--\==0....
....../___\........
......_| |_.........
Re: PCMON segmentation fault Dirk Zimoch
PCMON segmentation fault Nicoletta Petrella
Prev: Re: asyn vxi11 problem Dirk Zimoch
Next: Re: PCMON segmentation fault Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PCMON segmentation fault Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
