1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn vxi11 problem
To: [email protected]
Date: Tue, 29 Apr 2014 09:34:53 +0200
Hi Peter,
Maybe you are using a too old version of StreamDevice?
For most devices, I try to read first 1 byte with ReplyTimeout and then the rest with ReadTimeout. For serial and socket this works fine. But GPIB devices must be addressed to talk and then deliver complete messages. If I now ask for only 1 byte, the GPIB driver reports overflow. (Unfortunately it does not store the message in some local input buffer where could pick it up later.)
Thus I have modified StreamDevice to handle GPIB devices differently and read larger messages. I have changed that behavior quite some time ago.
BTW: At the moment, I am working on a more flexible solution, because there are other devices, that behave similarly without having a asynGpibType interface (e.g. usbtmc). Progress is slow however because of lack of time.
Dirk
On 28.04.2014 16:11, [email protected] wrote:
I’m trying to communicate with a scope using a vxi11 protocol with
stream device & asyn.
I can connect to the device and send output commands which appear to
work, but whenever I try to read a reply I get:
2014/04/28 15:09:21.411 FE-SCOPE-ReadIdent: asynOverflow:
2014/04/28 15:09:21.412 FE-SCOPE-ReadIdent: I/O error from device
2014/04/28 15:09:21.412 FE-SCOPE-ReadIdent: Protocol aborted
Any suggestions for what may be happening?
Pete
Scanned by iCritical.
RE: asyn vxi11 problem peter.owens
Re: asyn vxi11 problem Eric Norum
Prev: Acromag avme9670 LiuP
Next: Re: PCMON segmentation fault Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: asyn vxi11 problem peter.owens
Next: RE: asyn vxi11 problem peter.owens
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
