1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn vxi11 problem
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Tue, 29 Apr 2014 08:48:21 -0700
On Apr 29, 2014, at 12:34 AM, Dirk Zimoch <[email protected]> wrote:
> Hi Peter,
> Maybe you are using a too old version of StreamDevice?
> For most devices, I try to read first 1 byte with ReplyTimeout and then the rest with ReadTimeout. For serial and socket this works fine. But GPIB devices must be addressed to talk and then deliver complete messages. If I now ask for only 1 byte, the GPIB driver reports overflow. (Unfortunately it does not store the message in some local input buffer where could pick it up later.)
> Thus I have modified StreamDevice to handle GPIB devices differently and read larger messages. I have changed that behavior quite some time a
> BTW: At the moment, I am working on a more flexible solution, because there are other devices, that behave similarly without having a asynGpibType interface (e.g. usbtmc). Progress is slow however because of lack of time.
The asynUSBTMC driver does read large blocks from the device and buffers them for later delivery to higher level code.  This results in an extra copy operation but provides more flexibility in the size of transfers requested by the higher level code.  So StreamDevice should work as-is since the USBTMC semantics match those of serial and socket devices.
Eric Norum
[email protected]
asyn vxi11 problem peter.owens
Re: asyn vxi11 problem Dirk Zimoch
Prev: Re: PCMON segmentation fault Nicoletta Petrella
Next: Re: asyn vxi11 problem Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn vxi11 problem Dirk Zimoch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
