1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem with procServ and server port numbers
To: Tech Talk <[email protected]>
Date: Fri, 2 May 2014 17:33:48 +0100
Hi all,
I have two nearly identical soft IOCs on two separate linux machines; SL6.4, EPICS v3.14.12.3, procServ 2.6.0
Each updates the PV on the other machine such that I have an infinite loop between the computers.  Each of the
computers are running only 1 IOC for the test, but ultimately, I run several IOCs with different server ports
on a single PC.
I ran 4 tests to compare what happens when between running from the command line and using procServ
with port 5064 vs an arbitrary port 10000.  In all cases $EPICS_CA_AUTO_ADDR_LIST=NO.  For the cases
when I used procServ, I also did a tcpdump.
When running both IOCs from terminals with:
1) $EPICS_CA_ADDR_LIST="xxx.xxx.xxx.xxx:5064  and $EPICS_CA_SERVER_PORT=5064  yyy.yyy.yyy.yyy:5064":  2 IOCs work together
2) $EPICS_CA_ADDR_LIST="xxx.xxx.xxx.xxx:10000 and $EPICS_CA_SERVER_PORT=10000 yyy.yyy.yyy.yyy:10000": 2 IOCs work together
These results were expected.
When running both IOCs from procServ, and using the command:
procServ -i ^D^C --killsig 15 --name testSoftIOC --quiet 7004 /home/epics/epicsDEV/iocTops/testSoftIOC/iocBoot/ioctestSoftIOC/st.cmd
3) $EPICS_CA_ADDR_LIST="xxx.xxx.xxx.xxx:5064  and $EPICS_CA_SERVER_PORT=5064  yyy.yyy.yyy.yyy:5064":
The 2 IOCs work together successfully.  Then performing the tcpdump, I get:
[root@miceiocpctest epics]# tcpdump -i eth0 -c 20 -n host yyy.yyy.yyy.yyy and port not 22
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
16:32:19.019788 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 1247694494:1247694590, ack 1297244695, win 245, options [nop,nop,TS val 717239303 ecr 687760235], length 96
16:32:19.021378 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 96:120, ack 1, win 245, options [nop,nop,TS val 717239305 ecr 687760235], length 24
16:32:19.021517 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 120:192, ack 1, win 245, options [nop,nop,TS val 717239305 ecr 687760235], length 72
16:32:19.021629 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 192:240, ack 1, win 245, options [nop,nop,TS val 717239305 ecr 687760235], length 48
16:32:19.021722 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 240:288, ack 1, win 245, options [nop,nop,TS val 717239305 ecr 687760235], length 48
16:32:19.021767 IP yyy.yyy.yyy.yyy.ca-1 > xxx.xxx.xxx.xxx.53292: Flags [.], ack 192, win 1002, options [nop,nop,TS val 687760243 ecr 717239303], length 0
16:32:19.021858 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 288:312, ack 1, win 245, options [nop,nop,TS val 717239305 ecr 687760243], length 24
16:32:19.021971 IP yyy.yyy.yyy.yyy.ca-1 > xxx.xxx.xxx.xxx.53292: Flags [.], ack 288, win 1002, options [nop,nop,TS val 687760243 ecr 717239305], length 0
16:32:19.022053 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 312:360, ack 1, win 245, options [nop,nop,TS val 717239305 ecr 687760243], length 48
16:32:19.022178 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 360:384, ack 1, win 245, options [nop,nop,TS val 717239306 ecr 687760243], length 24
16:32:19.022323 IP yyy.yyy.yyy.yyy.ca-1 > xxx.xxx.xxx.xxx.53292: Flags [.], ack 360, win 1002, options [nop,nop,TS val 687760244 ecr 717239305], length 0
16:32:19.022451 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 384:432, ack 1, win 245, options [nop,nop,TS val 717239306 ecr 687760244], length 48
16:32:19.022565 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 432:480, ack 1, win 245, options [nop,nop,TS val 717239306 ecr 687760244], length 48
16:32:19.022765 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 480:552, ack 1, win 245, options [nop,nop,TS val 717239306 ecr 687760244], length 72
16:32:19.022794 IP yyy.yyy.yyy.yyy.ca-1 > xxx.xxx.xxx.xxx.53292: Flags [.], ack 432, win 1002, options [nop,nop,TS val 687760244 ecr 717239306], length 0
16:32:19.022947 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 552:600, ack 1, win 245, options [nop,nop,TS val 717239306 ecr 687760244], length 48
16:32:19.023000 IP yyy.yyy.yyy.yyy.ca-1 > xxx.xxx.xxx.xxx.53292: Flags [.], ack 552, win 1002, options [nop,nop,TS val 687760244 ecr 717239306], length 0
16:32:19.023088 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 600:648, ack 1, win 245, options [nop,nop,TS val 717239306 ecr 687760244], length 48
16:32:19.023194 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 648:672, ack 1, win 245, options [nop,nop,TS val 717239307 ecr 687760244], length 24
16:32:19.023312 IP xxx.xxx.xxx.xxx.53292 > yyy.yyy.yyy.yyy.ca-1: Flags [P.], seq 672:720, ack 1, win 245, options [nop,nop,TS val 717239307 ecr 687760244], length 48
20 packets captured
745 packets received by filter
665 packets dropped by kernel
4) $EPICS_CA_ADDR_LIST="xxx.xxx.xxx.xxx:10000 and $EPICS_CA_SERVER_PORT=10000 yyy.yyy.yyy.yyy:10000 yyy.yyy.yyy.yyy:10000":
The 2 IOCs fail to work together.  Then performing tcpdump:
16:42:26.806887 IP xxx.xxx.xxx.xxx.57809 > yyy.yyy.yyy.yyy.ndmp: Flags [P.], seq 3756718018:3756718034, ack 1282241670, win 229, options [nop,nop,TS val 717847090 ecr 688338034], length 16
16:42:26.807279 IP yyy.yyy.yyy.yyy.ndmp > xxx.xxx.xxx.xxx.57809: Flags [P.], seq 1:17, ack 16, win 227, options [nop,nop,TS val 688368029 ecr 717847090], length 16
16:42:26.807333 IP xxx.xxx.xxx.xxx.57809 > yyy.yyy.yyy.yyy.ndmp: Flags [.], ack 17, win 229, options [nop,nop,TS val 717847091 ecr 688368029], length 0
16:42:28.554708 IP xxx.xxx.xxx.xxx.60505 > yyy.yyy.yyy.yyy.ca-1: UDP, length 48
16:42:28.555064 IP yyy.yyy.yyy.yyy > xxx.xxx.xxx.xxx: ICMP yyy.yyy.yyy.yyy udp port ca-1 unreachable, length 84
16:42:28.586698 IP xxx.xxx.xxx.xxx.60505 > yyy.yyy.yyy.yyy.ca-1: UDP, length 48
16:42:28.587031 IP yyy.yyy.yyy.yyy > xxx.xxx.xxx.xxx: ICMP yyy.yyy.yyy.yyy udp port ca-1 unreachable, length 84
16:42:28.651191 IP xxx.xxx.xxx.xxx.60505 > yyy.yyy.yyy.yyy.ca-1: UDP, length 48
16:42:28.651529 IP yyy.yyy.yyy.yyy > xxx.xxx.xxx.xxx: ICMP yyy.yyy.yyy.yyy udp port ca-1 unreachable, length 84
16:42:28.778695 IP xxx.xxx.xxx.xxx.60505 > yyy.yyy.yyy.yyy.ca-1: UDP, length 48
16:42:28.779029 IP yyy.yyy.yyy.yyy > xxx.xxx.xxx.xxx: ICMP yyy.yyy.yyy.yyy udp port ca-1 unreachable, length 84
16:42:29.034729 IP xxx.xxx.xxx.xxx.60505 > yyy.yyy.yyy.yyy.ca-1: UDP, length 48
16:42:29.035077 IP yyy.yyy.yyy.yyy > xxx.xxx.xxx.xxx: ICMP yyy.yyy.yyy.yyy udp port ca-1 unreachable, length 84
16:42:30.830255 IP xxx.xxx.xxx.xxx.57810 > yyy.yyy.yyy.yyy.ndmp: Flags [P.], seq 1575505478:1575505494, ack 3147764375, win 245, options [nop,nop,TS val 717851114 ecr 688342057], length 16
16:42:30.830642 IP yyy.yyy.yyy.yyy.ndmp > xxx.xxx.xxx.xxx.57810: Flags [P.], seq 1:17, ack 16, win 243, options [nop,nop,TS val 688372053 ecr 717851114], length 16
16:42:30.830727 IP xxx.xxx.xxx.xxx.57810 > yyy.yyy.yyy.yyy.ndmp: Flags [.], ack 17, win 245, options [nop,nop,TS val 717851114 ecr 688372053], length 0
16:42:51.272682 IP yyy.yyy.yyy.yyy.39000 > xxx.xxx.xxx.xxx.ndmp: Flags [P.], seq 644595172:644595188, ack 798743394, win 245, options [nop,nop,TS val 688392495 ecr 717841561], length 16
16:42:51.272850 IP xxx.xxx.xxx.xxx.ndmp > yyy.yyy.yyy.yyy.39000: Flags [P.], seq 1:17, ack 16, win 243, options [nop,nop,TS val 717871556 ecr 688392495], length 16
16:42:51.273199 IP yyy.yyy.yyy.yyy.39000 > xxx.xxx.xxx.xxx.ndmp: Flags [.], ack 17, win 245, options [nop,nop,TS val 688392495 ecr 717871556], length 0
16:42:56.802546 IP xxx.xxx.xxx.xxx.57809 > yyy.yyy.yyy.yyy.ndmp: Flags [P.], seq 16:32, ack 17, win 229, options [nop,nop,TS val 717877086 ecr 688368029], length 16
20 packets captured
20 packets received by filter
0 packets dropped by kernel
What am I doing wrongly?
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
no response first time, so I'm trying again Pierrick Hanlet
Prev: Re: [SPAM] RE: cannot run medm rightly on ubuntu 13.04 ahwwq
Next: Point Grey Flea3 areaDetector ImageJ Viewer Problems Zachary Brown
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS opportunities at FRIB Hoff, Larry
Next: no response first time, so I'm trying again Pierrick Hanlet
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
