1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture
To: "J. Lewis Muir" <[email protected]>
Cc: Tonia Batten <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 5 May 2014 23:00:24 -0400
Intel is Little Endian - ARM can be either - how is the ARMv5 setup?  Big Endian or Little Endian?
What OS are you dealing with?  What compiler?
What happens if you move the double and int?  Could be padding issue in how the compilers for different ISA handle the alignment.  Is the Intel a 64bit CPU? (I know ARMv5 is not, that’s a “StrongArm” variant basically or Marvell. . .
Does the ARM compiler being used has proper library support for double?
Stephen Beckwith
On Sat, May 3, 2014 at 8:39 PM, J. Lewis Muir <[email protected]> wrote:
On 5/3/14, 5:32 PM, Mark Rivers wrote:
> Any idea how this could happen?
Hi, Mark.
Compiler bug?  Maybe try turning off all optimizations?
Lewis
RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Tonia Batten
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
Prev: QE Framework 2.8.1 Ricardo Fernandes
Next: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Torsten Bögershausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
Next: RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
