> Could be padding issue in how the compilers for different ISA handle the alignment.
That should not be an issue because the structure is only being accessed by code using the same definition of the structure. The structure is written to in one function and read from in another function in the same source code module. Packing should be irrelevant.
> Does the ARM compiler being used has proper library support for double?
It certainly appears to. The double values are being computed correctly in the motor record, and they are being printed correctly in this device support code.
Sent: Monday, May 05, 2014 10:00 PM
To: J. Lewis Muir
Cc: Mark Rivers; Tonia Batten; [email protected]
Subject: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture
Intel is Little Endian - ARM can be either - how is the ARMv5 setup? Big Endian or Little Endian?
What OS are you dealing with? What compiler?
What happens if you move the double and int? Could be padding issue in how the compilers for different ISA handle the alignment. Is the Intel a 64bit CPU? (I know ARMv5 is not, that’s a “StrongArm” variant basically or Marvell. . .
Stephen Beckwith
On Sat, May 3, 2014 at 8:39 PM, J. Lewis Muir <[email protected]<mailto:[email protected]>> wrote:
On 5/3/14, 5:32 PM, Mark Rivers wrote:
> Any idea how this could happen?
Hi, Mark.
Compiler bug? Maybe try turning off all optimizations?
Lewis
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Stephen Beckwith
- RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
- Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
<2014>
2025
2026
<2014>
2025
2026
