1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Application Export from CSS IDE
To: Ganesh Jangir <[email protected]>
Date: Fri, 9 May 2014 12:41:28 +0000
There is no CSS IDE vs. CSS Runtime.
There is just CSS.
If you have created *.opi displays, you can provide your users with a CSS installation that has set the preference setting
org.csstudio.opibuilder/no_edit = true
so that they can't open the *.opi files in the editor.
This would still allow advanced users to set the preference back to false, so they can edit the files, and help you make them better.
In that case, you might want to provide the *.opi files in a read-only file location, so users can open them for edit, but they would then use "Save-As" to write the modified files to a new location, so you can compare if the new files are really better and should replace/augment your original displays.
Or you serve your *.opi files via http://, setting the
org.csstudio.opibuilder/top_opis=http://your_server/main.opi
so your users can execute the *.opi files, but don't actually get the source code.
So it's really like EDM, MEDM, … where the 'display tool' and the 'editor tool' are one and the same.
In contrast to those, you can remove the org.csstudio.opibuilder.editor plugin from the end users' CSS installation, so they really have no way to edit the files.
-Kay
On May 9, 2014, at 5:17 AM, Ganesh Jangir <[email protected]<mailto:[email protected]>>
 wrote:
I have developed a simple application with 4 GUIs using CSS. Now I want to share this application with end user, who do not have CSS IDE.
Can any one please guide me in doing this. How this can be achieved?
Thanks!
-- -- Ganesh Jangir
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
Application Export from CSS IDE Ganesh Jangir
Prev: Application Export from CSS IDE Ganesh Jangir
Next: Portable Channel Access Server Event Queue Christopher J. Pendleton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
