1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Portable Channel Access Server Event Queue
From: "Christopher J. Pendleton" <[email protected]>
To: <[email protected]>
Date: Fri, 9 May 2014 12:10:54 -0400
Hello! I am using the portable channel access server API to provide EPICS
access to our devices. Some of our devices perform data acquisition at high
rates and send a buffer up to the server, which then calls the casPV class
method postEvent() repeatedly at a very high rate. When I run a client that
monitors this PV, I often see that some of the data samples are missing. I
suspect that this is a function of the queue size that postEvent()
populates, the rate at which it is populated, and the rate at which it is
offloaded by the client(s). Could someone please help me understand why the
client(s) would not receive the full set of data samples posted to the event
queue?
Chris
Director, Software Development
Pyramid Technical Consultants, Inc.
http://ptcusa.com/
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
Prev: Re: Application Export from CSS IDE Kasemir, Kay
Next: RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Tonia Batten
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Portable Channel Access Server Event Queue Christopher J. Pendleton
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
