1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RELEASE macro vanishes if USR_CXXFLAGS_Linux is set
To: <[email protected]>
Date: Mon, 19 May 2014 13:03:41 -0500
Hi Martin,
On 05/19/2014 12:45 PM, Konrad, Martin wrote:
> However, if I run make "USR_CXXFLAGS_Linux=-Werror=format-security" (one
> of the parameters used when compiling Michael's Debian package), g++ is
> not called with "-DALLOW_CAPUTLOG" anymore. It seems to ignore the
> CAPUTLOG entry in the configure/RELEASE file.
> Am I missing something or is this a bug?
This is a bug in the putlog modification to the gateway/Makefile:
> === modified file 'Makefile'
> --- Makefile	2009-09-17 15:45:45 +0000
> +++ Makefile	2014-04-15 19:56:08 +0000
> @@ -144,6 +144,14 @@
>  # need access to casCtx.h
>  USR_INCLUDES += -I$(EPICS_BASE)/src/cas/generic
> +# To compile in caPutLog functionality, define the location of the caPutLog
> +# module as 'CAPUTLOG' in the appropriate extensions configure/RELEASE* file
> +ifdef CAPUTLOG
> +  USR_LIBS_DEFAULT += caPutLog dbIoc
> +  USR_CXXFLAGS_DEFAULT += -DWITH_CAPUTLOG
> +  USR_CFLAGS_DEFAULT += -DWITH_CAPUTLOG
> +endif
>  PROD_HOST = gateway
This patch sets the _DEFAULT version of the USR_xxxx variables. This
means that as soon as one of the OS-specific variables gets set such as
you are doing on the command-line, the build system will no longer make
use of the _DEFAULT version of that variable. This is discussed in
section 4.3.6 of the Application Developers Guide
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node5.html#SECTION00560000000000000000
You need to remove _DEFAULT from the names of all the USR_xxx variables
you set in the Makefile so you just set USR_LIBS, USR_CFLAGS and
USR_CXXFLAGS.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RELEASE macro vanishes if USR_CXXFLAGS_Linux is set Konrad, Martin
Prev: Re: RELEASE macro vanishes if USR_CXXFLAGS_Linux is set Bob Soliday
Next: Re: RELEASE macro vanishes if USR_CXXFLAGS_Linux is set Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
