1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RELEASE macro vanishes if USR_CXXFLAGS_Linux is set
To: <[email protected]>
Date: Mon, 19 May 2014 13:02:02 -0500
From the Makefile that I see:
http://bazaar.launchpad.net/~info-martin-konrad/epics-gateway/putlog/view/head:/Makefile
You set:
USR_CXXFLAGS_DEFAULT += -DWITH_CAPUTLOG
Now if you are also setting USR_CXXFLAGS_Linux, it will use this flag on Linux and the DEFAULT on other operating systems. You might try changing:
to
USR_CXXFLAGS += -DWITH_CAPUTLOG
--Bob Soliday
On 05/19/2014 12:45 PM, Konrad, Martin wrote:
I'm experiencing the following issue with the EPICS build system:
I'm compiling the gateway code with our PutLog extensions [1]. This
requires setting CAPUTLOG=/usr/lib/epics on my Debian machine.
Everything works fine if I just run make. g++ is called with
"-DALLOW_CAPUTLOG" as it is supposed to be.
However, if I run make "USR_CXXFLAGS_Linux=-Werror=format-security" (one
of the parameters used when compiling Michael's Debian package), g++ is
not called with "-DALLOW_CAPUTLOG" anymore. It seems to ignore the
CAPUTLOG entry in the configure/RELEASE file.
Am I missing something or is this a bug?
Martin
P.S.: You can download a tarball [2] of my directory to reproduce the issue.
[1] https://code.launchpad.net/~info-martin-konrad/epics-gateway/putlog
[2] https://www.martin-konrad.net/gateway.tar.bz2
RELEASE macro vanishes if USR_CXXFLAGS_Linux is set Konrad, Martin
Prev: RELEASE macro vanishes if USR_CXXFLAGS_Linux is set Konrad, Martin
Next: Re: RELEASE macro vanishes if USR_CXXFLAGS_Linux is set Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
