1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: procServ and user id
To: EPICS Tech Talk <[email protected]>
Date: Wed, 21 May 2014 19:07:44 +0000
> We use procServ to run IOCs on Linux using a non-root user id.
Thank you all for sharing your experience! After looking into this a bit
closer it looks like I can do that as well. I was just hoping that
procServ could save some work setting up permissions for log directories
etc. by opening the log files as root and then dropping permissions. But
this of course does not work since log files are closed and opened again
when the process inside procServ is restarted...
> Are you seeing problems running procServ under a non-root account?
Nothing that cannot be sorted out... Just some non-optimal defaults of
the Debian packages I am using.
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: procServ and user id Ralph Lange
procServ and user id Konrad, Martin
Prev: Re: procServ and user id Hartman, Steven M.
Next: TCP and UDP port numbers fr multiple IOCs Hovanes Egiyan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: procServ and user id Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
