1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: procServ and user id
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 22 May 2014 10:26:48 +0200
On 21/05/2014 21:07, Konrad, Martin wrote:
> Thank you all for sharing your experience! After looking into this a
> bit closer it looks like I can do that as well. I was just hoping that
> procServ could save some work setting up permissions for log
> directories etc. by opening the log files as root and then dropping
> permissions. But this of course does not work since log files are
> closed and opened again when the process inside procServ is restarted...
Obviously, procServ has no influence on what the child process is doing
with the file system. For whatever operation the child wants to do, it
should better have the necessary permissions.
procServ's own log files are not closed and reopened when the child
process is restarted.
(As in real life, the parent can only do so much about a misbehaving
child...)
Cheers,
~Ralph
procServ and user id Konrad, Martin
Re: procServ and user id Konrad, Martin
Prev: Re: TCP and UDP port numbers fr multiple IOCs Andrew Johnson
Next: RE: Portable Channel Access Server Event Queue Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: procServ and user id Konrad, Martin
Next: TCP and UDP port numbers fr multiple IOCs Hovanes Egiyan
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
