Hi Ned,
Yes, your approach is really a quicker way. How about the idea of integrating your code (or similar implementation) with the field TPRO in the dbProcess()?
I did a quick test and put your code in base-3.14.12.2/src/db/dbAccess.c. With a few other changes on Makefile, I re-compiled my EPICS base and example ioc without problem. And the code below works: if recordName.TPRO is set to 1, this will show more information -- who is doing CA put from which machine, the message like this:
CAS-client: Process yhuHost:aiExample
CA put to yhuHost:aiExample by user yhu from host box32
/*trying to adapt Ned's code inside dbProcess()*/
long epicsShareAPI dbProcess(dbCommon *precord)
if(*ptrace) printf("%s: Process %s\n",
epicsThreadGetNameSelf(), precord->name);
if(*ptrace){
tid = epicsThreadGetIdSelf();
LOCK_CLIENTQ;
for(pclient=(struct client*)ellFirst(&clientQ);
pclient && pclient->tid!=tid;
pclient=(struct client*)ellNext(&pclient->node)
if(pclient)
sprintf(result,"user %s from host %s",pclient->pUserName,pclient->pHostName);
else
sprintf(result,"Internal: TID = %p",tid);
UNLOCK_CLIENTQ;
printf("CA put to %s by %s\n",precord->name,result);
/* process record */
status = (*prset->process)(precord);
Yong
From: [email protected] [[email protected]] on behalf of Arnold, Ned D. [[email protected]]
Sent: Thursday, May 22, 2014 9:47 AM
To: LEI Ge; [email protected]
Subject: RE: how to know which PVs write to a PV
Yet another <quicker> way to determine which host wrote to a PV:
1) Load a subroutine record into the IOC using the code below
2) Include this subroutine record in the record processing chain of the record you want to monitor. You can use a FLNK or SDIS for this (make sure that it is *not* a CA or CP link).
When the record processes, you see something like this ...
ioclic1> caHostId: ioclic1:caHostId1: nda from chiron
We have a few of these subroutine records in all IOCs, so if we need to track down an errant "write" we can just change a few links ... without rebooting.
Ned
RECORD
record(sub,"$(IOC):caHostId1") {
field(INAM,"caHostIdI")
field(SNAM,"caHostId")
SUBROUTINE
/* subroutine for determining host/uid of CA client
* DESC : String identifying Username & Host
#include <stdio.h>
#include <string.h>
#include <dbEvent.h>
#include <osiSock.h>
#include <ellLib.h>
#include <server.h>
#include <dbDefs.h>
#include <registryFunction.h>
#include <subRecord.h>
#include <epicsExport.h>
static long caHostIdI(subRecord* pr)
return(0);
static long caHostId(subRecord* pr)
char result[100];
epicsThreadId tid = epicsThreadGetIdSelf();
struct client* pclient;
LOCK_CLIENTQ;
if(pclient)
sprintf(result,"%s from %s",pclient->pUserName,pclient->pHostName);
else
UNLOCK_CLIENTQ;
strncpy(pr->desc, result, sizeof(pr->desc));
pr->desc[sizeof(pr->desc)-1] = '\0';
db_post_events(pr, pr->desc, 1);
pr->val = pr->a; /* set val to value of Input A */
printf("caHostId: %s: %s\n",pr->name,result);
return(0);
static registryFunctionRef caHostIdRef[] = {
{"caHostIdI",(REGISTRYFUNCTION)caHostIdI},
{"caHostId",(REGISTRYFUNCTION)caHostId}
static void caHostIdRegister(void)
registryFunctionRefAdd(caHostIdRef,NELEMENTS(caHostIdRef));
epicsExportRegistrar(caHostIdRegister);
From: [email protected] [[email protected]] on behalf of LEI Ge [[email protected]]
Sent: Wednesday, May 21, 2014 03:54 AM
To: [email protected]
Subject: how to know which PVs write to a PV
Hi, all,
This week we met a problem, a PV's value should be 1 (to enable our e-gun trigger), but sometimes it becomes 0 unexpectedly. I checked the software logic I can remember to this pv, and have not found the reason. Maybe there is some logic I forget or I don't know, to write to this pv. So is there a way to check in our control system, which PVs write to this pv? Or, this PV is written from which IP?
Thanks a lot ,
Ge
- Re: how to know which PVs write to a PV Andrew Johnson
- how to know which PVs write to a PV LEI Ge
- RE: how to know which PVs write to a PV Arnold, Ned D.
how can I caget a PV's Value in the callback function of the caClient? ahwwq
Job opportunities at ESS Timo Korhonen
<2014>
2025
2026
<2014>
2025
2026
