1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Visual Studio 2010 problem and solution
Date: Wed, 28 May 2014 11:53:28 -0400
I found the same thing as well - it seems to be an issue with the newest version of .NET.
When building base on 64-bit windows, I install .NET 4.0, then the Win7 SDK to get VS2010 (and the necessary 64bit compilers, for some reason these are not included with VS.).
On Wed, May 28, 2014 at 11:07 AM, Mark Rivers <[email protected]> wrote:
Folks,
We recently installed some Windows Updates on our machines, and found that Visual Studio 2010 then failed to build DLLs when building EPICS base, for example:
>    Creating library Com.lib and object Com.exp
> Generating code
> Finished generating code
> LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
Andrew Johnson found a Web page discussing this problem, which contained the solution.
The solution is to install Visual Studio 2010 SP1.  I am not sure exactly which Windows Update caused the problem, but it may be an update to .NET.
I'm posting this to save others needing to rediscover the solution.
Visual Studio 2010 problem and solution Mark Rivers
Prev: Visual Studio 2010 problem and solution Mark Rivers
Next: RE: Visual Studio 2010 problem and solution Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
