1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Visual Studio 2010 problem and solution
To: "Mark Rivers" <[email protected]>, "EPICS Tech Talk" <[email protected]>
Date: Wed, 28 May 2014 17:03:35 +0100
Hi Mark,
Yes, you will need the service pack before it works normally.
The service pack would normally be installed (after some time) by means of Windows Update.
It's better to do it manually.
I would advise also installing the .NET framework 4.51.
(.NET 4.0 will be installed with VS2010.)
Cheers,
Peter.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 28 May 2014 16:08
To: EPICS Tech Talk
Subject: Visual Studio 2010 problem and solution
Folks,
We recently installed some Windows Updates on our machines, and found that Visual Studio 2010 then failed to build DLLs when building EPICS base, for example:
>    Creating library Com.lib and object Com.exp Generating code
> Finished generating code LINK : fatal error LNK1123: failure during
> conversion to COFF: file invalid or corrupt
Andrew Johnson found a Web page discussing this problem, which contained the solution.
The solution is to install Visual Studio 2010 SP1.  I am not sure exactly which Windows Update caused the problem, but it may be an update to .NET.
I'm posting this to save others needing to rediscover the solution.
Visual Studio 2010 problem and solution Mark Rivers
Prev: Re: Visual Studio 2010 problem and solution Zachary Brown
Next: subclassing Pyepics epics.motor doesn't work as expected Terry Cornall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Visual Studio 2010 problem and solution Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
