1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: TD20 classic : Turbo molecular pump controller
To: 최숙 <[email protected]>
Cc: [email protected]
Date: Mon, 2 Jun 2014 08:43:49 -0700
This type of instrument will be rather hard to test using a simple terminal program.  Lots of non-ASCII characters to type.
But it shouldn’t be too hard to write support using StreamDevice.
In particular, StreamDevice makes it easy to generate the simple ‘XOR’ check byte that the Siemens USS protocol requires.
Or, perhaps someone has already written an ASYN interpose interface to handle the USS protocol?
On Jun 1, 2014, at 10:47 PM, 최숙 <[email protected]> wrote:
I need helps... ^.^
I have a TD20 Classic turbo molecular pump controller... it was produced by Leybold..
First, I want to signal test using terminal program like hyperterminal..
 It uses USS protocol.. I got a signal hexacode... I attached the document.
It can or can not ?
 Second, I want to control by SIEMENS PLC or AB PLC ...then integrate into EPICS..
 Anyone who got a source.. control TD20 classic TMP controller... help me..
Sincerely,  Suk Choi
Eric Norum
[email protected]
TD20 classic : Turbo molecular pump controller "최숙"
Prev: Re: WG: Re: motorRecord on linux-arm Ron Sluiter
Next: protol file erro: Field width out of range 张德敏
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: TD20 classic : Turbo molecular pump controller "최숙"
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
