Dear all,
I am just trying StreamDevice2.3 to control our equipment ADAM4117. But I met some problems, the ioc will crash quickly after starting:
[fel@localhost iocAPP]$ ../../bin/linux-x86/APP st.cmd
#!../../bin/linux-x86/APP ## You may have to change APP to something else ## everywhere it appears in this file #< envPaths epicsEnvSet(STREAM_PROTOCOL_PATH,"../../db") ## Register all support components dbLoadDatabase("../../dbd/APP.dbd",0,0) APP_registerRecordDeviceDriver(pdbbase) drvAsynIPPortConfigure("G7","192.168.127.253:5008",0,0,0) ## Load record instances ##dbLoadRecords("../../db/PSM.db","user=fel") ##dbLoadRecords("../../db/pump-2.db","user=fel") dbLoadRecords("../../db/pump-4.db","user=fel") iocInit() Starting iocInit ############################################################################ ## EPICS R3.14.9- $R3-14-9-pre1$ $2006/11/20 21:09:36$ ## EPICS Base built Mar 21 2013 ############################################################################ 2014/06/03 16:38:24.770 'ADAM4117.proto' line 6: Field width 1090600 out of range
2014/06/03 16:38:24.770 'ADAM4117.proto' line 6: in format string: "%0001090600" 2014/06/03 16:38:24.770 'ADAM4117.proto' line 6: in command 'out' 2014/06/03 16:38:24.770 'ADAM4117.proto' line 6: in protocol 'setting' 2014/06/03 16:38:24.770 while compiling protocol 'setting' for 'ADAM4117:set' 2014/06/03 16:38:24.770 ADAM4117:set: Protocol parse error 2014/06/03 16:38:24.770 ADAM4117:set: Record initialization failed Bad init_rec return value PV: ADAM4117:set ao: init_record iocInit: All initialization complete ## Start any sequence programs #seq sncAPP,"user=fel" epics> ADAM4117.proto #This is ADAM4117 protocol file Terminator=cr ;
setting{
out "%0001090600"; } getting {
out "#010"; in "%c"; } Can anybody give me some hints? thanks a lot for your help.
| ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
