1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EDM 64-bit bug
To: Andrew Johnson <[email protected]>, EPICS tech-talk <[email protected]>, Janet Anderson <[email protected]>
Date: Wed, 4 Jun 2014 20:55:53 +0000
I'll take a look.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Wednesday, June 04, 2014 1:57 PM
To: EPICS tech-talk; Janet Anderson
Subject: EDM 64-bit bug
We've discovered a problem in EDM (including latest release) when built for a 64-bit target.
The attached image shows two copies of a couple of EDM screens, the top ones are from a 32-bit executable and the bottom ones a 64-bit one. The plots from the 64-bit version have zero values inserted in between most of the valid sample points, which probably indicates that the code is using a long* instead of an epicsInt32* somewhere. In the right-hand screen the plot scrolls slowly left-wards, and when only one sample curve is displayed the new data points that appear on the right don't get the interleaved zero values any more (but the graph auto-scaling never recovers even after all the zeros have scrolled off the left side of the plot).
I'm hoping that whoever is currently maintaining the relevant EDM widget will recognize this issue and be able to fix it. We will be happy to test any patches/fixes...
- Andrew
Advertising may be described as the science of arresting the human intelligence long enough to get money from it. -- Stephen Leacock
EDM 64-bit bug Andrew Johnson
Prev: RE: sequencer installation Mark Rivers
Next: RE: DC Power supplies with EPICS support James.OHea
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM 64-bit bug Andrew Johnson
Next: sequencer installation Vikram Bhagat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
