1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM 64-bit bug
To: EPICS tech-talk <[email protected]>, Janet Anderson <[email protected]>
Date: Wed, 4 Jun 2014 12:56:30 -0500
We've discovered a problem in EDM (including latest release) when built
for a 64-bit target.
The attached image shows two copies of a couple of EDM screens, the top
ones are from a 32-bit executable and the bottom ones a 64-bit one. The
plots from the 64-bit version have zero values inserted in between most
of the valid sample points, which probably indicates that the code is
using a long* instead of an epicsInt32* somewhere. In the right-hand
screen the plot scrolls slowly left-wards, and when only one sample
curve is displayed the new data points that appear on the right don't
get the interleaved zero values any more (but the graph auto-scaling
never recovers even after all the zeros have scrolled off the left side
of the plot).
I'm hoping that whoever is currently maintaining the relevant EDM widget
will recognize this issue and be able to fix it. We will be happy to
test any patches/fixes...
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Attachment: Libera Screen Shots with FA.png
Description: PNG image
RE: EDM 64-bit bug Sinclair, John William
Prev: Re: DC Power supplies with EPICS support Pearson, Matthew R.
Next: sequencer installation Vikram Bhagat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EDM 64-bit bug Sinclair, John William
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
