1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS database Feature request
To: EPICS mailing list <[email protected]>
Date: Fri, 6 Jun 2014 08:22:43 -0700
Hello all,
A feature I use a lot with my db  file is overwriting a record, ie:
record(ao, "myAO") {
   field(VAL, "20")
   field(DRVH, "40")
and later in the same or another db file
   field(VAL, "21")
   field(FLNK, "AnotherAO")
The above is equivalent to  1 single entry with
record(ao, "mAO") {
  field(VAL, "21")
  field(DRVH, "40")
Now the issue is that to overwrite the field of a record, you need to know its type (i.e. ao) as you need to repeat the record line.
Is it possible to have a database entry (maybe like the alias entry) where you could just say:
changefield("myAO", VAL, 21)
which doesn't create the record if it doesn't exist, but which perform the equivalent to
  field(VAL, "21")
if it does.
Maybe a similar command already exist.
If so let me know,
Emmanuel
Re: EPICS database Feature request Shen, Guobao
Re: EPICS database Feature request Pearson, Matthew R.
Re: EPICS database Feature request Pete Jemian
Prev: wrong SADR field declaration in genSub haquin
Next: RE: areaDetector acquirePeriod and acquireTime Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS database Feature request Shen, Guobao
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
