1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS database Feature request
To: [email protected]
Date: Fri, 06 Jun 2014 11:48:52 -0400
Hi Emmanuel,
Not sure whether I fully understand your question, but for an exiting record,
all default fields are there no matter you use it or not.
The difference is just what the exact value it has.
For you first example: the FLNK is CONSTANT 0, and DRVH is 40
you next example FLNK is "AnotherAO", and DRVH is 0.
Therefore, you are always able to change any existing field by for example using dbpf from iocsh
epics> dbpf anotherAO.VAL 10
Record 'anotherAO.VAL' not found
epics> dbpf myAO.VAL 10
DBR_DOUBLE:         10
epics>
But again, I might miss something.
Guobao
On 6/6/14, 11:22 AM, Emmanuel Mayssat wrote:
Hello all,
A feature I use a lot with my db  file is overwriting a record, ie:
record(ao, "myAO") {
   field(VAL, "20")
   field(DRVH, "40")
and later in the same or another db file
   field(VAL, "21")
   field(FLNK, "AnotherAO")
The above is equivalent to  1 single entry with
record(ao, "mAO") {
  field(VAL, "21")
  field(DRVH, "40")
Now the issue is that to overwrite the field of a record, you need to know its type (i.e. ao) as you need to repeat the record line.
Is it possible to have a database entry (maybe like the alias entry) where you could just say:
changefield("myAO", VAL, 21)
which doesn't create the record if it doesn't exist, but which perform the equivalent to
  field(VAL, "21")
if it does.
Maybe a similar command already exist.
If so let me know,
Emmanuel
EPICS database Feature request Emmanuel Mayssat
Prev: RE: areaDetector acquirePeriod and acquireTime Mark Rivers
Next: Porting EPICS to a new OS Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS database Feature request Emmanuel Mayssat
Next: Re: EPICS database Feature request Pearson, Matthew R.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
