1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Writing areadetector driver- Getting array data to NDArray properly?
From: "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]>
Date: Mon, 9 Jun 2014 02:20:10 +0000
Hi Mark,
Thank you very much for the quick response. I modified my code to read how you have it. I also realized that my NDArraySize was off by a factor of 2 (did not take into account sizeof(USHORT)).
The AD Tiff plugin now works (earlier I would get a pop up dialog- I forget exactly what it said but something along the lines of "Error opening tiff". )
ImageJ Viewer still isn't working but I was just using it as a test to see if my driver was working. It is the latest version (same as one currently on github). I checked in my ioc and EPICS_CA_MAX_ARRAY_BYTES is 300000000 (i bumped it up a factor of 10 earlier to be sure).
I restarted ImageJ but it still doesnt work, but getting the IJ viewer working is low priority seeing how much work I have left in this driver. I am just happy to have the arrays reading out now.
Thanks!
Andrew
Sent: Sunday, June 08, 2014 9:43 PM
To: Gomella, Andrew (NIH/NHLBI) [F]; [email protected]
Hi Andrew,
Note that while what you are doing should work (unless there is a problem I am missing), it is not the most efficient way to do it.  You can avoid allocating 2 arrays and the memcpy operation if you change the order of operations as follows:
this->pArrays[0] = this->pNDArrayPool->alloc(2, dims, NDUInt16, 0, NULL);
pImage = this->pArrays[0];
vip_get_image(this->ModeNumber, VIP_CURRENT_IMG_RAW, this->sensorWidth, this->sensorHeight,
                     (USHORT *)pImage->pData);
So you pass the NDArray data pointer directly to their DLL.
From: [email protected] [[email protected]] on behalf of Gomella, Andrew (NIH/NHLBI) [F] [[email protected]]
Sent: Sunday, June 08, 2014 7:12 PM
To: [email protected]
Subject: Writing areadetector driver- Getting array data to NDArray properly?
Hi Everyone,
I am writing a driver for a Varian 3024m flat panel detector. I am having trouble in my driver getting the data from the panel into NDArrays.
To get the data from the panel it is fairly simple, I pass a pointer to the dll (with the call vip_get_image) and it populates it with  ushorts. It looks like this:
USHORT *pFrame = new USHORT[this->sensorSize];
vip_get_image(this->ModeNumber, VIP_CURRENT_IMG_RAW, this->sensorWidth, this->sensorHeight, pFrame);
Next I attempt to get this data to NDPluginStdArrays with:
(This is just one of many attempts, I tried my best to follow examples from other areadetector drivers, mainly Prosilica and PerkinElmer).
NDArray *pImage;
dims[0] = this->sensorWidth;
dims[1] = this->sensorHeight;
if (this->pArrays[0])
       this->pArrays[0]->release();
pImage->getInfo(&arrayInfo);
memcpy(pImage->pData, pFrame, arrayInfo.totalBytes);
setIntegerParam(NDArraySize,  arrayInfo.totalBytes);
setIntegerParam(NDArraySizeX, arrayInfo.xSize);
setIntegerParam(NDArraySizeY, arrayInfo.ySize);
setIntegerParam(NDDataType, dataType);
setIntegerParam(NDColorMode, colorMode);
getIntegerParam(NDArrayCallbacks, &arrayCallbacks);
if (arrayCallbacks) {
    this->unlock();
    doCallbacksGenericPointer(pImage, NDArrayData, 0);
    this->lock();
Testing this, Tiff plugin gives me an error about not being able to open it and the Imagej Plugin just shows a black window with a  "UpdateImage got exception: pendIO timed out" error. My EPICS_MAX_CA_ARRAY_BYTES is set to 30MB, and all appropriate array callback/ image callbacks are enabled for this test. System is Windows x64, i7 processor, 16gb ram. Area detector 1-9-1.
My other attempts, which there are too numerous to mention here result in the app crashing.
Any help is greatly appreciated.
Andrew Gomella
Imaging Physics Lab, NIH
RE: Writing areadetector driver- Getting array data to NDArray properly? Mark Rivers
Writing areadetector driver- Getting array data to NDArray properly? Gomella, Andrew (NIH/NHLBI) [F]
Prev: RE: Writing areadetector driver- Getting array data to NDArray properly? Mark Rivers
Next: RE: Writing areadetector driver- Getting array data to NDArray properly? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
