1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn module installation
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 11 Jun 2014 13:09:48 -0700 (PDT)
   I have problem for asyn module installation.
/usr/bin/ar -rc   libtestSupport.a        echoDriver.o addrChangeDriver.o devTestBlock.o interposeInterface.o asynExample.o
/usr/bin/ranlib libtestSupport.a
rm -f libtestSupport.so.
/usr/bin/g++ -o libtestSupport.so. -shared -fPIC -Wl,-hlibtestSupport.so. -L/opt/epics/modules/asyn4-22/lib/linux-x86_64 -L/opt/epics/base-3.15.0.1/lib/linux-x86_64 -Wl,-rpath,/opt/epics/modules/asyn4-22/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base-3.15.0.1/lib/linux-x86_64       -m64               echoDriver.o addrChangeDriver.o devTestBlock.o interposeInterface.o asynExample.o    -lasyn -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libtestSupport.so.
Installing library ../../../lib/linux-x86_64/libtestSupport.a
make[3]: *** No rule to make target `test_registerRecordDeviceDriver.cpp', needed by `test_registerRecordDeviceDriver.o'.  Stop.
make[3]: Leaving directory `/opt/epics/modules/asyn4-22/testApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/opt/epics/modules/asyn4-22/testApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/opt/epics/modules/asyn4-22/testApp'
make: *** [testApp.install] Error 2
I am now able to under stand what is problem to install.
The configure/RELEASE file set as below
#RELEASE Location of external products
#SUPPORT=/corvette/home/epics/devel
SUPPORT=/opt/epics/modules
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
#  IPAC is only necessary if support for Greensprings IP488 is required
#  IPAC release V2-7 or later is required.
#IPAC=$(SUPPORT)/ipac-2-11
# SEQ is required for testIPServer
#SNCSEQ=$(SUPPORT)/seq-2-1-10
SNCSEQ=$(SUPPORT)/sncseq
#  EPICS_BASE 3.14.6 or later is required
LINUX_GPIB=NO
#EPICS_BASE=/corvette/usr/local/epics/base-3.14.12.3
EPICS_BASE=/opt/epics/base-3.15.0.1
-include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
Can you point my mistake?
With Best Regards
Vikram
RE: asyn module installation Mark Rivers
Prev: Fw: sequencer installation Vikram Bhagat
Next: Re: asyn module installation Vikram Bhagat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: device/driver support for NRM METROLAB PT2025 Jack
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
