1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn module installation
To: "'Vikram Bhagat'" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 11 Jun 2014 21:44:00 +0000
You appear to be using EPICS base 3.15.0.1.  Where did you get that?  Did you get it from this Web page?
http://www.aps.anl.gov/epics/base/R3-15/0.php
If so, that Web page explicitly says:
base-3.15.0.1.tar.gz (31 July 2012) Do not use, old version!
Or did you fetch a more recent version of 3.15 using Bazaar?
As I said in a previous message when you were having trouble with the sequencer, 3.15 is really not ready for production use and I strong suggest you use 3.14.12.4 until 3.15 is ready for normal use.
From: [email protected] [mailto:[email protected]] On Behalf Of Vikram Bhagat
Sent: Wednesday, June 11, 2014 3:10 PM
To: EPICS Tech-Talk
Subject: asyn module installation
   I have problem for asyn module installation.
/usr/bin/ar -rc   libtestSupport.a        echoDriver.o addrChangeDriver.o devTestBlock.o interposeInterface.o asynExample.o
/usr/bin/ranlib libtestSupport.a
rm -f libtestSupport.so.
/usr/bin/g++ -o libtestSupport.so. -shared -fPIC -Wl,-hlibtestSupport.so. -L/opt/epics/modules/asyn4-22/lib/linux-x86_64 -L/opt/epics/base-3.15.0.1/lib/linux-x86_64 -Wl,-rpath,/opt/epics/modules/asyn4-22/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base-3.15.0.1/lib/linux-x86_64       -m64               echoDriver.o addrChangeDriver.o devTestBlock.o interposeInterface.o asynExample.o    -lasyn -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libtestSupport.so.
Installing library ../../../lib/linux-x86_64/libtestSupport.a
make[3]: *** No rule to make target `test_registerRecordDeviceDriver.cpp', needed by `test_registerRecordDeviceDriver.o'.  Stop.
make[3]: Leaving directory `/opt/epics/modules/asyn4-22/testApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/opt/epics/modules/asyn4-22/testApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/opt/epics/modules/asyn4-22/testApp'
make: *** [testApp.install] Error 2
I am now able to under stand what is problem to install.
The configure/RELEASE file set as below
#RELEASE Location of external products
#SUPPORT=/corvette/home/epics/devel
SUPPORT=/opt/epics/modules
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
#  IPAC is only necessary if support for Greensprings IP488 is required
#  IPAC release V2-7 or later is required.
#IPAC=$(SUPPORT)/ipac-2-11
# SEQ is required for testIPServer
#SNCSEQ=$(SUPPORT)/seq-2-1-10
SNCSEQ=$(SUPPORT)/sncseq
#  EPICS_BASE 3.14.6 or later is required
LINUX_GPIB=NO
#EPICS_BASE=/corvette/usr/local/epics/base-3.14.12.3
EPICS_BASE=/opt/epics/base-3.15.0.1
-include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
Can you point my mistake?
With Best Regards
Vikram
RE: asyn module installation Mark Rivers
asyn module installation Vikram Bhagat
Prev: Re: asyn module installation Vikram Bhagat
Next: RE: asyn module installation Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
