1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: sequencer installation
To: "'Vikram Bhagat'" <[email protected]>, epics talk <[email protected]>
Date: Fri, 13 Jun 2014 17:41:03 +0000
It looks to me like you have not correctly defined EPICS_BASE in sncseq/configure/RELEASE.
Sent: Friday, June 13, 2014 12:39 PM
To: Mark Rivers; epics talk
Subject: Re: sequencer installation
I installed base3.14.12.4 but for installation of sequencer, i have
below error
make[1]: Leaving directory `/opt/epics/modules/sncseq/configure'
make -C ./src install
make[1]: Entering directory `/opt/epics/modules/sncseq/src'
make -C ./pv install
make[2]: Entering directory `/opt/epics/modules/sncseq/src/pv'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64
install
make[3]: Entering directory
`/opt/epics/modules/sncseq/src/pv/O.linux-x86_64'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory
make[2]: Leaving directory `/opt/epics/modules/sncseq/src/pv'
make -C ./seq install
make[2]: Entering directory `/opt/epics/modules/sncseq/src/seq'
install
`/opt/epics/modules/sncseq/src/seq/O.linux-x86_64'
make[3]: *** No rule to make target
`../../../lib/linux-x86_64/libiocsh.a', needed by `libseq.a'.  Stop.
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/opt/epics/modules/sncseq/src/seq'
make[1]: *** [seq.install] Error 2
make[1]: Leaving directory `/opt/epics/modules/sncseq/src'
make: *** [src.install] Error 2
Please suggest me how to come out from this problem.
With best Regards
Vikram
On Wednesday, June 4, 2014 10:40 PM, Mark Rivers <[email protected]> wrote:
I would suggest using 3.14.12.4 and see if you still have a problem.
Sent: Wednesday, June 04, 2014 3:14 PM
Dear Mark
There nothing special to use EPICS3.15,  i am installing in my system so just took latest.
Vikram
On Wednesday, June 4, 2014 10:09 PM, Mark Rivers <[email protected]> wrote:
You are using EPICS 3.15.  Do you have a reason for using that?  It is still not ready for production systems.  Should you be using 3.14.12.4 instead?
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of Vikram Bhagat [[email protected]<mailto:[email protected]>]
Sent: Wednesday, June 04, 2014 3:02 PM
To: epics talk
Subject: sequencer installation
Hello,
    I am trying to install sequencer but could not build
Below is the log an anyone guide me what is wrong with installation.
[root@sarva-PC<mailto:root@sarva-PC> sncseq]# make
make -C ./configure install
make[1]: Entering directory `/opt/epics/modules/sncseq/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/opt/epics/modules/sncseq/configure/O.linux-x86_64'
perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/opt/epics/modules/sncseq/configure/O.linux-x86_64'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64'
make[3]: *** No rule to make target `/opt/epics/base-3.15.0.1/include/shareLib.h', needed by `pvNew.o'.  Stop.
make[3]: Leaving directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64'
make[1]: *** [pv.install] Error 2
I set
EPICS_BASE=/opt/epics/base
in configure/RELEASE
Thanks
Vikram
Re: sequencer installation Andrew Johnson
Re: sequencer installation Vikram Bhagat
RE: sequencer installation Mark Rivers
Prev: Re: sequencer installation Vikram Bhagat
Next: Re: Writing areadetector driver- Getting array data to NDArray properly? Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: sequencer installation Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
