1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer installation
To: <[email protected]>
Date: Fri, 13 Jun 2014 14:06:08 -0500
On 06/13/2014 12:41 PM, Mark Rivers wrote:
> It looks to me like you have not correctly defined EPICS_BASE in
> sncseq/configure/RELEASE.
EPICS_BASE has to have been defined correctly or there wouldn't have
been any build rules at all, but it looks like it might not have been
built (or not built for this target), which might be why the libiocsh.a
library can't be found.
- Andrew
> *From:*Vikram Bhagat [mailto:[email protected]]
> *Sent:* Friday, June 13, 2014 12:39 PM
> *To:* Mark Rivers; epics talk
> *Subject:* Re: sequencer installation
> I installed base3.14.12.4 but for installation of sequencer, i have
> below error
> make[1]: Leaving directory `/opt/epics/modules/sncseq/configure'
> make -C ./src install
> make[1]: Entering directory `/opt/epics/modules/sncseq/src'
> make -C ./pv install
> make[2]: Entering directory `/opt/epics/modules/sncseq/src/pv'
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64
> install
> make[3]: Entering directory
> `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory
> make[2]: Leaving directory `/opt/epics/modules/sncseq/src/pv'
> make -C ./seq install
> make[2]: Entering directory `/opt/epics/modules/sncseq/src/seq'
> install
> `/opt/epics/modules/sncseq/src/seq/O.linux-x86_64'
> make[3]: *** No rule to make target
> `../../../lib/linux-x86_64/libiocsh.a', needed by `libseq.a'.  Stop.
> make[2]: *** [install.linux-x86_64] Error 2
> make[2]: Leaving directory `/opt/epics/modules/sncseq/src/seq'
> make[1]: *** [seq.install] Error 2
> make[1]: Leaving directory `/opt/epics/modules/sncseq/src'
> make: *** [src.install] Error 2
> Please suggest me how to come out from this problem.
> With best Regards
> Vikram
> On Wednesday, June 4, 2014 10:40 PM, Mark Rivers
> <[email protected] <mailto:[email protected]>> wrote:
> I would suggest using 3.14.12.4 and see if you still have a problem.
> ________________________________
> From: Vikram Bhagat [[email protected] <mailto:[email protected]>]
> Sent: Wednesday, June 04, 2014 3:14 PM
> To: Mark Rivers; epics talk
> Dear Mark
> There nothing special to use EPICS3.15,  i am installing in my system so
> just took latest.
> Vikram
> On Wednesday, June 4, 2014 10:09 PM, Mark Rivers
> You are using EPICS 3.15.  Do you have a reason for using that?  It is
> still not ready for production systems.  Should you be using 3.14.12.4
> instead?
> Mark
> From: [email protected]
> <mailto:[email protected]><mailto:[email protected]
> <mailto:[email protected]>> [[email protected]
> <mailto:[email protected]>>] on behalf of Vikram Bhagat
> [[email protected]
> Sent: Wednesday, June 04, 2014 3:02 PM
> To: epics talk
> Subject: sequencer installation
> Hello,
>     I am trying to install sequencer but could not build
> Below is the log an anyone guide me what is wrong with installation.
> [root@sarva-PC <mailto:root@sarva-PC><mailto:root@sarva-PC
> <mailto:root@sarva-PC>> sncseq]# make
> make -C ./configure install
> make[1]: Entering directory `/opt/epics/modules/sncseq/configure'
> make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
> `/opt/epics/modules/sncseq/configure/O.linux-x86_64'
> perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
> `/opt/epics/base-3.15.0.1/include/shareLib.h', needed by `pvNew.o'.  Stop.
> make[3]: Leaving directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64'
> make[1]: *** [pv.install] Error 2
> I set
> EPICS_BASE=/opt/epics/base
> in configure/RELEASE
> Thanks
> Vikram
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
sequencer installation Vikram Bhagat
RE: sequencer installation Mark Rivers
Re: sequencer installation Vikram Bhagat
Prev: Re: Writing areadetector driver- Getting array data to NDArray properly? Hu, Yong
Next: EtherIP with CIP Adapter Devices John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: sequencer installation Mark Rivers
Next: Re: sequencer installation Vikram Bhagat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
