1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EtherIP with CIP Adapter Devices
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 13 Jun 2014 16:07:07 -0400
We have an Allen-Bradley Power Monitor 3000 which we want to incorporate into our controls. This device supports various protocols including EtherIP which is supported in EPICS as device support for ContolLogix and CompactLogix PLCs. The Power Monitor 3000 however uses EtherIP in a different fashion than the PLCs. The
Power Monitor is known as an Adapter device in CIP (Common Industrial Protocol which is the basis for EtherIP).  It makes itself available for Implicit and Explicit messaging.
CIP  defines various types of Objects. One of these objects is called an Assembly object and is intended to be a generic container for data. The Power Monitor has dozens of Assembly object instances. Each Assembly object has an attribute called 'data' which is a container for an array of numbers, either shorts or floating points. One can read this attribute via Explicit Messaging using the CIP service "Get_Attribute_Single", a service which is already implemented in the EPICS EtherIP support. I found it was straightforward to add support for the CIP service "Set_Attribute_Single" allowing me to control the Power Monitor 3000.
I know of other devices similar to the Power Monitor 3000. For example, we use an EX250 pneumatic controller from SMC Corp. We originally purchased this device with a modbus/tcp interface but one day someone unintentionally purchased several units on e-bay with an EtherIP interface. At the time we solved the problem by having a ContolLogix PLC read the data from the EX250 and map it into tags. In the case of the EX250 there were only two Assembly objects containing a few words of data. In the case of the Power Monitor 3000 there are dozens of Assembly objects each containing tens of words so I was interested in implementing an approach that by-passed the PLC.
I am currently working on a stand alone Java application (using Kay Kasemir's Java version of EtherIP) but wanted to share that support for these types of devices is possible.
John Dobbins​
Re: EtherIP with CIP Adapter Devices Kasemir, Kay
Prev: Re: sequencer installation Andrew Johnson
Next: RE: Visual Studio 2010 problem and solution Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Compiling helloWorld of EPICS V4 on 64bit linux had a link error [SEC=UNOFFICIAL] david.hickin
Next: Re: EtherIP with CIP Adapter Devices Kasemir, Kay
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
