Hi Matthew,
Thanks for the advice. I initially had some problems there but fixed them.
Mark took a look at my code and realized I was doing something very wrong- assigning the protected integer param variable names to values when I should just be using setIntegerParam etc. I should have realized this was a bad idea from the start considering they are all int values in the class declaration.
Thanks all for the help,
Andrew
Sent: Tuesday, June 17, 2014 9:46 AM
To: Gomella, Andrew (NIH/NHLBI) [F]
Cc: Mark Rivers; [email protected]
Subject: Re: Parameter library in asynportdriver /areadetector
Is the data member initialized correctly when you add an entry to the parameter list in the constructor?
eg:
createParam(My_FirstParamString, asynParamInt32, &My_FirstParam_);
It's also a good idea to initialize parameters, after they are created:
setIntegerParam(My_FirstParam__, 0)
(and check that asynSuccess is returned from the set function).
Cheers,
Matt
On Jun 16, 2014, at 7:42 PM, "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]>
wrote:
> I see. I checked over my database and I think there were some problems with it but the strings do match.
> The problem is when i put the names of one of my parameters in the writeint32 function instead of the index coming out, I am actually getting the value of that Parameter. I checked this by doing printf of parameter names in my writeInt32 function like this:
> printf("Varian Mode %i SaveRaw %i SaveOffset %i SaveCorrected", VarianMode, SaveRaw, SaveOffset, SaveCorrected);
> And instead of their indices, I get the values. This is my first C++ program ever, I am probably missing something trivial.
> That's a good point- I will change my parameter strings accordingly.
> Thanks!
> Andrew
> From: Mark Rivers [[email protected]]
> Sent: Monday, June 16, 2014 5:41 PM
> Cc: [email protected]
> Maybe the problem is your database record for the VarianMode record. Does it's drvInfo field match the definition for that parameter string in your driver?
> In general I would recommendations that you prefix all of your parameter strings with VARIAN_ to avoid potential future conflicts with base class parameters.
> Mark
> Sent from my iPhone
>> On Jun 16, 2014, at 4:26 PM, "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]> wrote:
>> As always thanks for the quick response. My output from report looks as expected:
>> Enabling software handshaking...camera connected
>> Port: PS1
>> Timestamp: <undefined>
>> Input EOS[0]:
>> Output EOS[0]:
>> Parameter list 0
>> Number of parameters is: 99
>> Parameter 0 type=string, name=PORT_NAME_SELF, value=PS1, status=0
>> Parameter 1 type=asynInt32, name=ARRAY_SIZE_X, value=1, status=0
>> Parameter 2 type=asynInt32, name=ARRAY_SIZE_Y, value=2816, status=0
>> Parameter 3 type=asynInt32, name=ARRAY_SIZE_Z, value=0, status=0
>> Parameter 4 type=asynInt32, name=ARRAY_SIZE, value=20185088, status=0
>> Parameter 5 type=asynInt32, name=ARRAY_NDIMENSIONS, value=0, status=0
>> Parameter 6 type=asynInt32, name=ARRAY_DIMENSIONS, value is undefined
>> Parameter 7 type=asynInt32, name=DATA_TYPE, value=3, status=0
>> Parameter 8 type=asynInt32, name=COLOR_MODE, value=0, status=0
>> Parameter 9 type=asynInt32, name=UNIQUE_ID, value=0, status=0
>> Parameter 10 type=asynFloat64, name=TIME_STAMP, value=0.000000, status=0
>> Parameter 11 type=asynInt32, name=EPICS_TS_SEC, value=0, status=0
>> Parameter 12 type=asynInt32, name=EPICS_TS_NSEC, value=0, status=0
>> Parameter 13 type=asynInt32, name=BAYER_PATTERN, value=0, status=0
>> Parameter 14 type=asynInt32, name=ARRAY_COUNTER, value=0, status=0
>> Parameter 15 type=string, name=FILE_PATH, value is undefined
>> Parameter 16 type=asynInt32, name=FILE_PATH_EXISTS, value is undefined
>> Parameter 17 type=string, name=FILE_NAME, value is undefined
>> Parameter 18 type=asynInt32, name=FILE_NUMBER, value is undefined
>> Parameter 19 type=string, name=FILE_TEMPLATE, value=%s%s_%3.3d.dat, status=0
>> Parameter 20 type=asynInt32, name=AUTO_INCREMENT, value is undefined
>> Parameter 21 type=string, name=FULL_FILE_NAME, value is undefined
>> Parameter 22 type=asynInt32, name=FILE_FORMAT, value is undefined
>> Parameter 23 type=asynInt32, name=AUTO_SAVE, value is undefined
>> Parameter 24 type=asynInt32, name=WRITE_FILE, value=0, status=0
>> Parameter 25 type=asynInt32, name=READ_FILE, value=0, status=0
>> Parameter 26 type=asynInt32, name=WRITE_MODE, value is undefined
>> Parameter 27 type=asynInt32, name=WRITE_STATUS, value=0, status=0
>> Parameter 28 type=string, name=WRITE_MESSAGE, value=, status=0
>> Parameter 29 type=asynInt32, name=NUM_CAPTURE, value is undefined
>> Parameter 30 type=asynInt32, name=NUM_CAPTURED, value=0, status=0
>> Parameter 31 type=asynInt32, name=CAPTURE, value=0, status=0
>> Parameter 32 type=asynInt32, name=DELETE_DRIVER_FILE, value is undefined
>> Parameter 33 type=string, name=ND_ATTRIBUTES_FILE, value is undefined
>> Parameter 34 is undefined, name=ARRAY_DATA
>> Parameter 35 type=asynInt32, name=ARRAY_CALLBACKS, value is undefined
>> Parameter 36 type=asynInt32, name=POOL_MAX_BUFFERS, value=50, status=0
>> Parameter 37 type=asynInt32, name=POOL_ALLOC_BUFFERS, value=0, status=0
>> Parameter 38 type=asynInt32, name=POOL_FREE_BUFFERS, value=0, status=0
>> Parameter 39 type=asynFloat64, name=POOL_MAX_MEMORY, value is undefined
>> Parameter 40 type=asynFloat64, name=POOL_USED_MEMORY, value is undefined
>> Parameter 41 type=string, name=MANUFACTURER, value=Varian, status=0
>> Parameter 42 type=string, name=MODEL, value=PaxScan 3024M X-ray Imager, status=0
>> Parameter 43 type=asynFloat64, name=GAIN, value is undefined
>> Parameter 44 type=asynInt32, name=BIN_X, value is undefined
>> Parameter 45 type=asynInt32, name=BIN_Y, value is undefined
>> Parameter 46 type=asynInt32, name=MIN_X, value is undefined
>> Parameter 47 type=asynInt32, name=MIN_Y, value is undefined
>> Parameter 48 type=asynInt32, name=SIZE_X, value=3584, status=0
>> Parameter 49 type=asynInt32, name=SIZE_Y, value=2816, status=0
>> Parameter 50 type=asynInt32, name=MAX_SIZE_X, value=3584, status=0
>> Parameter 51 type=asynInt32, name=MAX_SIZE_Y, value=2816, status=0
>> Parameter 52 type=asynInt32, name=REVERSE_X, value is undefined
>> Parameter 53 type=asynInt32, name=REVERSE_Y, value is undefined
>> Parameter 54 type=asynInt32, name=FRAME_TYPE, value is undefined
>> Parameter 55 type=asynInt32, name=IMAGE_MODE, value is undefined
>> Parameter 56 type=asynInt32, name=NEXPOSURES, value is undefined
>> Parameter 57 type=asynInt32, name=NEXPOSURES_COUNTER, value=0, status=0
>> Parameter 58 type=asynInt32, name=NIMAGES, value is undefined
>> Parameter 59 type=asynInt32, name=NIMAGES_COUNTER, value=0, status=0
>> Parameter 60 type=asynFloat64, name=ACQ_TIME, value is undefined
>> Parameter 61 type=asynFloat64, name=ACQ_PERIOD, value is undefined
>> Parameter 62 type=asynFloat64, name=TIME_REMAINING, value=0.000000, status=0
>> Parameter 63 type=asynInt32, name=STATUS, value=0, status=0
>> Parameter 64 type=asynInt32, name=TRIGGER_MODE, value is undefined
>> Parameter 65 type=asynInt32, name=ACQUIRE, value=0, status=0
>> Parameter 66 type=asynInt32, name=SHUTTER_CONTROL, value is undefined
>> Parameter 67 type=asynInt32, name=SHUTTER_CONTROL_EPICS, value is undefined
>> Parameter 68 type=asynInt32, name=SHUTTER_STATUS, value=0, status=0
>> Parameter 69 type=asynInt32, name=SHUTTER_MODE, value is undefined
>> Parameter 70 type=asynFloat64, name=SHUTTER_OPEN_DELAY, value is undefined
>> Parameter 71 type=asynFloat64, name=SHUTTER_CLOSE_DELAY, value is undefined
>> Parameter 72 type=asynFloat64, name=TEMPERATURE, value is undefined
>> Parameter 73 type=asynFloat64, name=TEMPERATURE_ACTUAL, value is undefined
>> Parameter 74 type=asynInt32, name=READ_STATUS, value is undefined
>> Parameter 75 type=string, name=STATUS_MESSAGE, value=, status=0
>> Parameter 76 type=string, name=STRING_TO_SERVER, value=, status=0
>> Parameter 77 type=string, name=STRING_FROM_SERVER, value=, status=0
>> Parameter 78 type=asynInt32, name=VARIAN_MODE, value is undefined
>> Parameter 79 type=asynInt32, name=SAVE_RAW, value is undefined
>> Parameter 80 type=asynInt32, name=SAVE_OFFSET, value is undefined
>> Parameter 81 type=asynInt32, name=SAVE_CORRECTED, value is undefined
>> Parameter 82 type=asynInt32, name=BOARDSNBR, value is undefined
>> Parameter 83 type=asynInt32, name=COMPLETE, value is undefined
>> Parameter 84 type=asynInt32, name=READY_FOR_PULSE, value is undefined
>> Parameter 85 type=asynInt32, name=NUM_FRAMES, value is undefined
>> Parameter 86 type=asynInt32, name=NUM_PULSES, value is undefined
>> Parameter 87 type=asynFloat64, name=TEMP1, value is undefined
>> Parameter 88 type=asynFloat64, name=TEMP2, value is undefined
>> Parameter 89 type=asynFloat64, name=TEMP3, value is undefined
>> Parameter 90 type=asynFloat64, name=TEMP4, value is undefined
>> Parameter 91 type=asynFloat64, name=TEMP5, value is undefined
>> Parameter 92 type=asynFloat64, name=TEMP6, value is undefined
>> Parameter 93 type=asynInt32, name=GAIN_CAL, value is undefined
>> Parameter 94 type=asynInt32, name=GAIN_CAL_NUM_OFFSETS, value is undefined
>> Parameter 95 type=asynInt32, name=GAIN_CAL_NUM_FLATS, value is undefined
>> Parameter 96 type=asynFloat64, name=VARIAN_FRAME_RATE, value is undefined
>> Parameter 97 is undefined, name=empty
>> Parameter 98 is undefined, name=empty
>> But when writeInt32 is called for say VarianMode, it thinks the parameter number for VarianMode is 1, when it should be 78? I'm probably missing something trivial but I really can't find it.
>> Thank you,
>> Andrew
>> Sent: Monday, June 16, 2014 3:35 PM
>> If your driver has a varian::report method like other drivers then you can do
>> asynReport 10 portName
>> where portName is the asyn port name of your driver.
>> That will dump the entire parameter library with index numbers, drvInfo strings and parameter values.
>> You should see the parameters from asynNDArrayDriver first, then the ones from ADDriver, and finally the ones from your Varian driver.
>> Mark
>> Sent from my iPhone
>>> On Jun 16, 2014, at 1:24 PM, "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]> wrote:
>>> Hi,
>>> Yet another question regarding an areadetector driver I am writing (which is now mostly finished).
>>> For some reason my parameter library is not getting set to the correct indices. In my writeInt32 function I put some printf statements and found out that my first parameter VarianMode is set to 3, but should be set to 78. (or vice versa?)
>>> synStatus varian::writeInt32(asynUser *pasynUser, epicsInt32 value)
>>> int function = pasynUser->reason;
>>> //int status = asynSuccess;
>>> printf("VarianMode: %i", VarianMode);
>>> printf("writeint32 %i %i", function, value);
>>> if (function == 78){
>>> printf("function varian mode called");
>>> vip_select_mode(value); //varian function
>>> (Explicitly just saying function ==78 was my quick fix to get things working as expected).
>>> When I caput VarianMode 1
>>> the first printf gives: VarianMode: 3
>>> The second printf gives: writeint32 78 1
>>> I've compared my code to many areadetector examples and can't figure out what I am doing wrong? Everything I'm doing seems exactly the same -
>>> the declarations, the NUM PARAMS define (which is later used in the constructor)
>>> #define NUM_VARIAN_PARAMS ((int)(&LAST_VARIAN_PARAM - &FIRST_VARIAN_PARAM + 1))
>>> Any ideas?
>>> Thanks,
>>> Andrew
>>> Imaging Physics Lab, NIH
- Parameter library in asynportdriver /areadetector Gomella, Andrew (NIH/NHLBI) [F]
- Re: Parameter library in asynportdriver /areadetector Mark Rivers
- RE: Parameter library in asynportdriver /areadetector Gomella, Andrew (NIH/NHLBI) [F]
- Re: Parameter library in asynportdriver /areadetector Pearson, Matthew R.
RE: EDM XY Graph Allison, Stephanie
Potential failure mode with pmacAsynMotor Emma Shepherd
<2014>
2025
2026
ASYN port driver for file IO? Ralph Lange
<2014>
2025
2026
