1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN port driver for file IO?
To: Torsten Bögershausen <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 18 Jun 2014 10:12:29 +0200
Hi Torsten,
On 18/06/2014 08:43, Torsten Bögershausen wrote:
thats sounds too interesting to keep quiet.
What, more specific,  do you want to do ?
Read a specific file line-by-line ?
Yes. Why not.
Do you need all the lines, or only a specifc one ?
Yes. Possibly both.
Do you want to read the file multiple times ?
Yes. Or maybe not?
In this case you could write a little daemon,
I could, but I don't want to...
Do you want to share more details ?
Sure.
My specific use case is reading statistics data from a file in the /proc file system, using StreamDevice to pull the numbers out.
But, obviously, I want to have something that is more versatile, maybe to an extent that it's worth adding it to the ASYN package.
So, I am thinking along the following lines.
st.cmd:
# drvAsynReadFilePortConfigure port fileName priority Autoconnect noProcessEos
drvAsynReadFilePortConfigure("mem","/proc/meminfo",0,1,0)
connect/disconnect = open/close
statsfile.proto:
freshD { out "o\$1"; in "%*s%d" }
Control through writing:
    g = goto line
    o = reopen and goto line
    line numbers: 0 = don't move (next line), negative = from the end of the file
database:
record (longin, "memFree") {
    field(DTYP, "stream")
    field(INP, "@statsfile.proto freshD(2) mem")
Other applications could include refreshing the last n lines of some (log) file into a char array, or ......
Windows/Linux line endings would be handled through EOS processing, interpose layers could do interesting things.
An similar (slightly simpler) drvAsynWriteFilePort could allow writing to a file (overwriting or appending).
File IO is something that is traditionally hard to do on an IOC - this approach might provide an easy way for many use cases.
What do you think?
~Ralph
Re: ASYN port driver for file IO? Benjamin Franksen
ASYN port driver for file IO? Ralph Lange
Re: ASYN port driver for file IO? Torsten Bögershausen
Prev: Re: ASYN port driver for file IO? Torsten Bögershausen
Next: Re: ASYN port driver for file IO? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
