1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: saveData vs 2G file size limit
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 20 Jun 2014 15:44:23 +0000
Hi Mark,
Unfortunately, this is a known problem.  saveData uses 32-bit file offsets within the MDA file.
I've been waiting for active development of scanSee (or of a scanSee replacement) to resume
before making any changes in the file format.  In retrospect, that was probably not a wise choice.
Tim
From: [email protected] [[email protected]] on behalf of Mark Davis [[email protected]]
Sent: Friday, June 20, 2014 8:21 AM
To: [email protected]
Subject: saveData vs 2G file size limit
We have run in to a problem I was hoping someone has a simple answer for.
We are running sscan (vers 2-9) records and saveData on a 64-bit Linux
system (3.2.0-4-amd64 #1 SMP Debian 3.2.46-1 x86_64 GNU/Linux) and
recently discovered that scans hang when the mda file being written
reaches 2GB in size.
Given the version of Linux (64-bit 3.2 kernel) and the filesystem being
used (ext4), I am guessing that the limit is not imposed by the OS, but
either by a library or saveData.
Has anyone run in to this before?  Is there an easy way to fix this?
Mark Davis
NSCL/FRIB
saveData vs 2G file size limit Mark Davis
Prev: saveData vs 2G file size limit Mark Davis
Next: asyn R4-23 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
