1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: saveData vs 2G file size limit
Date: Fri, 20 Jun 2014 09:21:40 -0400
We have run in to a problem I was hoping someone has a simple answer for.
We are running sscan (vers 2-9) records and saveData on a 64-bit Linux system (3.2.0-4-amd64 #1 SMP Debian 3.2.46-1 x86_64 GNU/Linux) and recently discovered that scans hang when the mda file being written reaches 2GB in size.
Given the version of Linux (64-bit 3.2 kernel) and the filesystem being used (ext4), I am guessing that the limit is not imposed by the OS, but either by a library or saveData.
Has anyone run in to this before?  Is there an easy way to fix this?
Mark Davis
NSCL/FRIB
RE: saveData vs 2G file size limit Mooney, Tim M.
Prev: RE: Generating a 'binary output pulse' by processing an ao record? Arnold, Ned D.
Next: RE: saveData vs 2G file size limit Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Generating a 'binary output pulse' by processing an ao record? [SEC=UNCLASSIFIED] LYNCH, Damien
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
